i think my little lights in the headlight are burned out. how can i replace them?
pop the hood and you can see the connection on the back of the headlight....rotate the plug counter-clockwise (i think, hey, i hava a 50/50 shot here) and it will pull out...replace bulb and stick it back in and you are done.....
check lexus buld reference guide for the correct bulb.....you are looking for the parking light 168
ps - these are the parking lights, so check to make sure they are really burned out before replacing (since you said "i think" they are burned out)
pss - i stole the link from here
thanks, do you have a picture of what i need to rotate?
thanks
I am replacing the bulbs on mine tonight, so i will snap some peectures and post them.......
thanks, that helped. i took out the bulbs and they are not burned out... when do these damn lights come on?? i know they are parking lights but i mean WTF!!!! ive never seen them on. how can i test them? or see them in action>>???
ANYONE????? :(
ANYONE????? :(
move the lights switch (on the turn signal arm) to the off position, the first setting/click up is the parking lights...they should come on then, but with standard bulbs you will have to bend over to see them, they are not bright at all....if they are not on then replace the bulbs and work from there.....
this is all in your owner's manual
  • 3 weeks later...
twist the housing counter-clockwise
pull it out, change the bulb
stick it in stick it in stick it in
i used these 921-x9 from superbrightleds.com
I was thinking about gettign these but there is a meessage saying this on there "Warning: do not use in headlamp housings - heat will cause LED failure and VOID WARRANTY ! "
Iv got LED in mine & have had no problems ;) its the indicators that dont blink correct but that cab be corrected ;)
I did mine & im a Girl lol :lol:
Iv got LED`s all over my Lex
Me too. Mine also said don't use them in a heated housing but no problems ever. They are just CTA so they don't have to replace a 3 cent item which they charge a few bucks for.
I think he used red and green. ^_^
What color bulbs did you use. White or blue?
white... the "don't use in the heated housing blah blah blah" is a total CYA move...standard fare for after-market parts...like the "for off-road use only" statements....i would love see the donkey that puts a set of headers on his/her IS and takes it off-road....
Uh, race track is off road.
