andre Posted December 9, 2007 Posted December 9, 2007 hello guys, have noticed recently that my economy light on dashbord ( under not too heavy acceleration ) comes on RED alot earlier then before and the kickdown is not as quick as earlier :(( any sugestions why? regs andre
andre Posted December 9, 2007 Author Posted December 9, 2007 hello guys,have noticed recently that my economy light on dashbord ( under not too heavy acceleration ) comes on RED alot earlier then before and the kickdown is not as quick as earlier :(( any sugestions why? regs andre also have noticed bit uneven work of the engine, while traveling steadly at a speed in the 1500 -2000rpm range :( any ideas why this is happening? regs
VMF Posted December 9, 2007 Posted December 9, 2007 hmm, economy light? have not heard about this light on US/Canadian models.
andre Posted December 9, 2007 Author Posted December 9, 2007 hmm, economy light? have not heard about this light on US/Canadian models. hello VMF, it is an european car, the lights are on the left side , bottom of the dash, under the rev counter regs
Sanpete Posted December 9, 2007 Posted December 9, 2007 Try asking here (if they have this in the UK): http://www.lexusownersclub.co.uk/forum/ind...hp?showforum=48 Or here, if your German is OK: http://euro.lexusownersclub.com/forums/index.php?showforum=6
andre Posted December 10, 2007 Author Posted December 10, 2007 thanks Sanpete, I'll try... but what about my kickdown problem, any ideas regs
VMF Posted December 11, 2007 Posted December 11, 2007 it might be related to that economy light, so i guess you should ask that on the UK or german forums as well
andre Posted December 12, 2007 Author Posted December 12, 2007 i'm getting as much help over there as in here :(
blake918 Posted December 12, 2007 Posted December 12, 2007 Can you take a picture of the economy light or describe it further?
nc211 Posted December 12, 2007 Posted December 12, 2007 Yes, please. A picture would be perfect. I don't think I've ever heard of an "economy" light in the LS before, at least over here on this side of the pond. Sounds like a wiring short in the switch on gear lever that we use for ECT settings...would be my guess. Like the car is telling him he is in econ mode, instead of pwr mode.
VBdenny Posted December 13, 2007 Posted December 13, 2007 Seems to me that an economy light is usually nothing more than a vacuum gauge of sorts. If you were to have a vacuum leak, it would probably cause the light to illuminate prematurely. Such a leak could also cause loss of engine power. I think it gets cold in Poland which makes old vacuum hoses very hard and prone to leaking, espcially at the connection points. Spray a little starting fluid around the hoses when the car is running and you will know pretty quickly.
NewGuy19 Posted December 13, 2007 Posted December 13, 2007 I think VBdenny is on the right track on this. I put a fuel economy gauge on my old dodge truck back in high school so I could see just how poor my gas mileage was. All most economy gauges are is a gauge connected to a vaccume line that is connected to the intake and measure economy off of that. If your line is cracked somewhere or you have a dirty intake it will give you a false reading. I ran into the same problem with the one I put on my truck the first winter after I installed it. My gauge never really read above a moderate fuel economy, even at idle. I checked the line and sure enough there was a small crack right where the line connected to gauge.
andre Posted December 13, 2007 Author Posted December 13, 2007 Seems to me that an economy light is usually nothing more than a vacuum gauge of sorts. If you were to have a vacuum leak, it would probably cause the light to illuminate prematurely. Such a leak could also cause loss of engine power. I think it gets cold in Poland which makes old vacuum hoses very hard and prone to leaking, espcially at the connection points. Spray a little starting fluid around the hoses when the car is running and you will know pretty quickly. Hello VB, I think you are preety close to it... which are the vacum hoses that I should check? -what about my second problem with uneven engine in the 1500-2000rpm range regs andre ps. I'll try to take and post some photos of the "economy" lights in the next few days...
