17LexusOwner Posted November 7, 2007 Share Posted November 7, 2007 Recently my left turn signal light went out. I was wondering if anyone had a link to a tutorial at how to get the front orange covers off. There aren't any bolts holding them on and I'm afraid if I try to pry them off I will end up braking the plastic. (already happened with the right marker cover cause i was impatient :/ ) Any help is greatly appreciated. P.S. Also if you just have a plain tutorial or tips on replacing them if you don't have to take that plastic cover off that'd be great too. Quote Link to comment Share on other sites More sharing options...
steve2006 Posted November 7, 2007 Share Posted November 7, 2007 Recently my left turn signal light went out. I was wondering if anyone had a link to a tutorial at how to get the front orange covers off. There aren't any bolts holding them on and I'm afraid if I try to pry them off I will end up braking the plastic. (already happened with the right marker cover cause i was impatient :/ ) Any help is greatly appreciated. P.S. Also if you just have a plain tutorial or tips on replacing them if you don't have to take that plastic cover off that'd be great too. I don't know the year of your car but normally there is a single screw holding the unit into the fender,remove the screw and lift out that side move it sideways away from the car and it should come out. Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted November 7, 2007 Author Share Posted November 7, 2007 My car is a '91 LS400, there was a screw and i took it out, but when i tried to take the cover off it broke the back. Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted November 8, 2007 Share Posted November 8, 2007 As steve2006 said, the front turn signal on each side of the bumper is a "unit" - the amber lens is glued to the housing and the bulb is replaced from the rear once the entire turn signal unit is removed from the bumper. This vendor's webpage has a photo that shows that the bulb is replaced from the rear: http://www2.partstrain.com/v5/products.php...4294967022+9322 I don't know if this is a good price. Consider checking ebay or Sewell Lexus (Lexusparts.com). Quote Link to comment Share on other sites More sharing options...
17LexusOwner Posted November 8, 2007 Author Share Posted November 8, 2007 Well I get lights for free from work, so that's not a worry. I see that I have to unbolt it from the back though, I'll check that out and try and get it fixed. Thanks for the tip guys Quote Link to comment Share on other sites More sharing options...
pishta Posted November 8, 2007 Share Posted November 8, 2007 As steve2006 said, the front turn signal on each side of the bumper is a "unit" - the amber lens is glued to the housing and the bulb is replaced from the rear once the entire turn signal unit is removed from the bumper.This vendor's webpage has a photo that shows that the bulb is replaced from the rear: http://www2.partstrain.com/v5/products.php...4294967022+9322 I don't know if this is a good price. Consider checking ebay or Sewell Lexus (Lexusparts.com). How are those clear lens installed you get on Ebay? do you unglue the amber lens? Quote Link to comment Share on other sites More sharing options...
1990LS400 Posted November 9, 2007 Share Posted November 9, 2007 As steve2006 said, the front turn signal on each side of the bumper is a "unit" - the amber lens is glued to the housing and the bulb is replaced from the rear once the entire turn signal unit is removed from the bumper.This vendor's webpage has a photo that shows that the bulb is replaced from the rear: http://www2.partstrain.com/v5/products.php...4294967022+9322 I don't know if this is a good price. Consider checking ebay or Sewell Lexus (Lexusparts.com). How are those clear lens installed you get on Ebay? do you unglue the amber lens? I don't know if these "ebay" clear turn signals are the ones you are talking about but these on ebay also appear to have the lens glued to the housing: http://cgi.ebay.com/ebaymotors/Lexus-LS400...bayphotohosting I don't think I have seen separate removable turn signal lenses since the early 1970s -- most everything in front and rear turn signals and tail lights I have seen during the past 30+ years have the lens glued to the housing. Quote Link to comment Share on other sites More sharing options...
