waf102 Posted October 24, 2007 Posted October 24, 2007 Latch on trunk won't latch. The little hook can be easily moved with my finger. BTW...The trunk release works fine. It just APPEARS to be the latch. Any advice? Quick/cheap fixes? Who to take it to? No dealer close by...(plus I don't want to get reamed...) This sucks. Thanks in advance! -Bill
SKperformance Posted November 5, 2007 Posted November 5, 2007 Spray some pb blaster in the lock assembly , it may be sticking or the spring is shot on it.
ko90ls Posted November 5, 2007 Posted November 5, 2007 Spray some pb blaster in the lock assembly , it may be sticking or the spring is shot on it. Very Good Advice, try this first (WD-40 or whatever) However, If you need to replace the trunk latch it is very easy and should cost about $40 (what i paid). basically just a few (2?) bolts and a long metal bar that is routed to where the key hole area is.
