Station light as well as radio control lights are out. Really tought at night with center part of console lights out. Is bulb replacement easy, and anyone with advise on how to remove the radio console?
  • 3 weeks later...
ITs not a bulb problem its a resistor problem
The bright side is that is not engine related. But I can't believe that it is so tough to replace a lightbulb in the radio.
Yes, I have the same problem.
  • 3 weeks later...
what do you mean a resistor problem? i have the same problem, how do you fix this resistor problem? is this true with all of the lights on the radio console?
The search feature of this forum is a very useful tool. Using the search feature, I found this link: http://www.cureline.net/lex/audio/howto_li..._hu_pioneer.htm
As noted on cureline, fixing the radio LCD and lights is not nearly as easy as fixing the HVAC display.
Most people seem to send their radios to a professional when the lights or LCD fail. You might find try doing a search on Google --> http://www.google.com/search?hl=en&q=LS400+radio+repair
