91 Ls400 Timing Adjustment
2rotor
Ok I am getting ready to adjust the "mal-adjusted" timing on my LS. I am thinking of doing it as follows to avoid tearing the whole front end down.. But i have a couple questions first...
Here is my plan minus one step that I need help with..
STEP 1---Remove the airbox/intake to gain visual access to the crank pulley
STEP 2---Remove both the plastic cam covers
STEP 3---Potentially remove the ignition components on the cams
STEP 4---Remove #1 spark plug and get it to TDC
STEP 5---Align the crank pully with the 0 deg mark
STEP 6--- PLEASE HELP!!!!
HERE IS WHERE I NEED HELP
What I want to do is to somehow get the belt loose enough to move the cam over a tooth or two (on the passenger side) where the shade tree mechanic mal adjusted it. The passenger side header glows red so I am pretty sure that is where the timing issue is.. So in theory all I need to do was to remove the covers and turn the cam enough to line it up with the mark on the housing..
Can anyone help with tips and tricks? The belt and waterpump are new.... The engine has about 60k miles on the rebuild (269 on the chassis)
Thanks fellas.
