My car is missing the owners manual. And I have difficulty figuring out how to use the seat memory function.
Here's what I tried:
1) set the right pos for myself
2) while pressing [sET], press [1] for a while. Heard a Beep. Release
Sounds like I made it remember.....now I mess around with the settings. But nothing happens when I press the [1] button...
How should I use this function?
The seat position memory came out in the 04-05 models.
If you have an automatic, the key must be in the "on" position, and the transmission in park. If you have the manual tran, then the key must be "on" and the parking brake has to be applied.
You set the memory correctly. So I would move the seat around and then open the door, close it, put the key in and start the car, then hit 1 and it should return to the memorized postion.
I checked there but did not find any info regarding seat position buttons. Perhaps it was not there in 2002?
You can access the manual for your year at lexus.com by registering in the owners section.
