Corner Lights
I need to replace a burned out bulb on one of my corner lights but I dont know how to access it? Does the lens just pry out or do I need to remove a panel somewhere?
I tried to do a search for this, but couldnt find it anywhere. I also visited local auto parts stores to read up on the books, but no repair manuals were available on this car.
Anyone have a link to a "how to" on this? Please help.
Thanks!!!
Member1115, Keep in mind steps 3 through 5 will be different since your Sc has corner lights. Most likely, your bulb will just twist out like my turn signal light bulb on my '95. I think this way will be easier than the process shown above.
The way I changed the foglight bulb was:
1. Take a few of the bolt to the front fenders' splashguard off, pull the splash gaurd back and wedge it against the front tire. This wll give you access to the fog light casing.
2. The foglight will be enclosed, with a circular plastic cap. Turn it counter clock-wise to open the casing.
3. This will give you access to the bulb and socket. In the casing is a white plastic, the bulbs wire fits snug into the socket. I had to wiggle and tug, until I disconnected the wire.
4. Note there is a clasp holding the bulb in place do not open the clasp. Disconnect the the bulb from the socket first...because the clasp keeps the bulb from droping and getting in your way. To open the clasp, I believe you push down and it will unfasten.
5. When replacing the buld with a Holagen\ Xenon type of bulb DO NOT TOUCH THE GLASS with your hands it shortens the life of the bulb.
