If you change the transmission oil when you change your motor oil when should you change the transmission filter and is there a filter?
Thanks new member 2nd ls400 current model 98 LS400 97,000 miles
the filter is only a metal screen.
agree with dcfish, that with frequent trans oil changes, it's not necessary to clean filter.
