Acceleration Hiccup
Whenever my car takes off from a stop, in the 1000-1500rpm range, the power delivery is not as linear / smooth as it is from say, 2000 rpm and above. The engine doesn't feel like it will stall, but more of a hesitation to rev. Very subtle, but noticeable.
The problem is much worse though EVERY time I have been using the engine for braking. After I use the engine for braking excessively and then eventually come to a stop sign, the takeoff is similar to the above situation, only MUCH worse / MUCH closer to stalling.
Your thoughts anyone?
Thanks!
Thanks!
i have had the same prob i added fuel cleaner in the gas tank when it was on empty before fill up it actually helped a bit
