1991 Ls400 Smoke Smell
teek
My '91 LS400 was in my garage with the garage door closed when rags stored in the rafters caught fire. The car survived pretty well, however, it would be extremely difficult to clean smoke residue out of the cabin air ducts. Has anyone tried to convert the '91 no cabin filter to a '93 HEPA filter system. I can't find any pictures to see if by removing a section behind the glove box and replacing it with a '93 section containing a filter would do the trick. I am also going to try running an ozone generator in the car for 4 hours with the heater and the fan running on high.
Any ideas would be GREATLY APPRECIATED.
TERRY
My suggestion would be to just get some sort of air filtering system you can plug into the wall and run that with you car's air on at the same time. Seems like installing a filter system into the car would be rather difficult.
