Rx330driver Posted May 24, 2007 Posted May 24, 2007 Well my IS300 is equipped with Dunlops, and ive notice how easy it is to have the rear tale out in either dry or wet road conditions. In fact, today my trac light was blinking for like 10 seconds because i took a turn a little fast to avoid getting hit my traffic. the point of the story is that the trac light comes on pretty often, so how bad is this for the treadware...will i be getting patches, or what?
pingpong Posted May 31, 2007 Posted May 31, 2007 spinning tires or drifting alone uses lots of tires.. hah even on wet grounds uses tires as well but of course not as much as dry grounds. but hey.. better to waste some tires then get rearended yea?
dcfish Posted May 31, 2007 Posted May 31, 2007 Well my IS300 is equipped with Dunlops, and ive notice how easy it is to have the rear tale out in either dry or wet road conditions. In fact, today my trac light was blinking for like 10 seconds because i took a turn a little fast to avoid getting hit my traffic. the point of the story is that the trac light comes on pretty often, so how bad is this for the treadware...will i be getting patches, or what? The trac applies the brake to the spinning wheel, So it saves wear rather than wearing the tires. You won't get patches of wear on your tires.
djspawn00 Posted June 1, 2007 Posted June 1, 2007 just like dc said, the trac control is saving your tires... the question should be why do your tires lose traction so easily? packing a few extra horses under the hood and not sharing?
Rx330driver Posted June 2, 2007 Author Posted June 2, 2007 lol...those dunlops have horrible traction but they are the ones that lexus made OEM. Anyways, they are suppose to fit the sporty nature of the car. im not blaming the wear on the trac system, im just saying i must be slipping a lot of rubber away. those tires arent cheap either.
oslo Posted June 4, 2007 Posted June 4, 2007 My LS had bridgestones on it and they would spin out all the time. I upgraded to some sumitomo HTRZ II's and they grip much better. Fairly affordable, too. Not sure if they make 'em for you car though...
