Review Mirror
Does anyone have a problem with the review mirror vibrating when the sunroof is retracted....I mean is it so bad it looks like the cars behind are jumping around. I had the dash problem and got that taken care of. Any suggestions? This is my first lexus after having many hondas......
That seems to be a common problem. Some have been fixed by dealers who replaced parts or the entire mirror assembly.
Heres the W/O from one repair.
One dealership stated there was not a Lexus bulletin on this, but what they documented on the work order was "CENTER REAR VIEW MIRROR HAS EXCESSIVE PLAY IN IT GUEST STATE
SOP TECH 320
EXCESSIVE PLAY IN JOINT OF REAR VIEW MIRROR
REPLACE MIRROR ASSY
87810-53120"
The last number appears to be a part number.
Yes, my rearview mirror was replaced. I guess I use a little too much bass in my music, and it would shake the begeebers outta that mirror!!!! The new mirror (new IS) vibrates a little, but not as much. Haven't experienced it, however, with the sunroof retracted.
I brought my 06 IS 250AWD in recently about this same problem. They could not fix it and had to report the problem back to Lexus. They said that it is not the problem w/ the rearview mirror, it the way the wind flow in the car when the sunroff is retracted all the way. :(
