bobstoc Posted March 13, 2007 Share Posted March 13, 2007 I am about to hit 75000 miles on my '01 gs430. Dealer says I need the recommended 75k service which varies from $250-340 depending on which dealer I called. I'm thinking on just flushing my coolant and doing an oil change (needed). The 75k service (trans flush (already did), a/c filter, check brakes, check undercarriage, "gas additive", etc..) seemed unecessary. Any opinions? Quote Link to comment Share on other sites More sharing options...
stroked4.6 Posted March 14, 2007 Share Posted March 14, 2007 I wouldnt spend the extra money. Seems like you got it covered. You might want to replace the fuel filter if you havent done that yet. Quote Link to comment Share on other sites More sharing options...
djspawn00 Posted March 14, 2007 Share Posted March 14, 2007 save your money, do the oil, check the air filter, the coolant(stick with toyota coolant), maybe the power steering fluid if needed and you should be fine. I think your fuel filter is a lifetime maintenance free part. if you're gonna get your car up might as well change your differential fluid too... oh yead top it all off with a little tree airfreshner and you're good to go. Quote Link to comment Share on other sites More sharing options...
