The other day while driving, my lights dimmed and the radio and AC controls went dead. Now I cant turn them on at all. Everything else works just fine but I i just got brakes and calipers done. I was wondering if you guys could help me figure this problem out so i can save money.
Have you checked all the fuses both under the hood and under the dash?
When this happened did you hit a large bump or go in any deep puddles?
I checked under the hood but not the dash. And yes i hit a pothole if i recall.
My radio is intermittent barely working. And my AC fan sometimes works and sometimes does not. I went through some big puddles yesterday before it started acting up. What would that do? :blink: Thanks
Grab your manual and find the fuses that run the A/C and dash...Change the fuses and if it happens again you have a bad ground wire somewhere....
you may also want to take notice of if your battery light comes on, and maybe have your alternator checked somewhere. most places like autozone/o'reilys do it for free. i had a similar problem with my radio intermittently working and it was a warning sign my alternator was going bad. i hope thats not the case for you, but just a heads up. if the alternator gets too wet (deep puddles) then it can mess up easlily
