Yep me too. I tell ya...these black cars... <_< :rolleyes:
I did this in the morning before my drive to work - looked pretty darn good afterwards! Except for the windows of course. My windows seem to be my nemesis!! :lol:
No, you dont want to microfiber dry unless you've washed the vehicle. Rinsing can't remove ALL contaminants and rinsing, then drying the vehicle can cause scratching. You can rinse, then just drive and not dry...
what he said
do not under wipe the car with out it being cleaned first
it will scratch the paint especially black and fill it with hairline scratches
i prefer to use a power washer when i am to lazy to wash it
i use the soap rinse , then use the rinse spray
it works great for in bettween
wahing
Dammit!!! :angry::angry:
when i say rinse i didnt mean with a hose!i use the power washer to rinse it and then micro fiber it dry.i have a black car and i dont get no swirl marks after doing it with the micro towels.i did however get some swirls with terry cloth type towels!i should of said that before!also i first use the wiper method to dry most of it then the micro for the rest.seems to work good for me.
i do agree not to dry with terry cloth or any towel if you just mist the car with a hose because that will give swirl marks.
even with a power washer it
leaves debis and dirt on the surface
the reason why it can never clean a car properly unless it is washed with soap and a mitt or cloth
to remove therain and dirt marks form driving
i agree to.but i dont sit there and rub a spot over and over either.i give one wipe per section till its dry.so if you think about it its really not rubbing dirt into the paint as bad as a towel boy would do at a car wash!then again my car is very rarely that dirty anyway!hehe.i use that duster thing that picks up any dust off the car so only time my car is dirty is after it rains and we all now what it needs then! ;)
  • 8 months later...
just to clarify,
it is ok to wash with chamois right? Or is there a better non scratching alternative?
Same question with drying, after the blade, rinsing the chamois often of course
chamois are good to uses for a car with no dirt
but it is better to use a wool mitt as it has more depth to it to get the dirt deep inside and away from the cars surface or else it is like sandpaper if the dirt is all on the surface of the chamois.
i put my mitts in the washing machine every month and make sure is clean them after each use.
good point, now if I could only find one that actually says "lambs wool", the ones I find are oddly absent of the description of the material they are made of...
chenille is man made
it all depends on the depth of the pile to hold water and trap dirt deep inside is hairs.
Like Sharad says it really depends, both are good but a high quality Chenile is better than a low quality lambswool and vice versa. Chenile sheds until it is broken in which can be a huge PITA.
As for washing natural chamois you can't. I dont use Chamois anymore, I reccomend a waffle weave MF towel followed by a normal MF towel.
