Diy Rx350 Oil Change
What size oil filter wrench is needed to remove the end cap of the oil filter (how many millimeters and number of flutes)?
Where can I get an oil filter wrench that fits the RX350?
Is the oil filter location under the plastic access panel on the passenger front of vehicle?
Thanks
  • 1 year later...
Thanks
Anyone also know how many quarts of oil you put in after the old motor oil has drained? Thanks.
Thanks
6.5 with filter change :D :D :D
  • 1 year later...
Is it 65mm or 64mm? From what I gather online the TOY640 wrench referred to is 64mm. I bought some POS 65mm wrench at Pepboys which allowed sufficient torque to open it but I can't really tighten it very well as is slips. I think the outer flutes are actually 67mm.
With limited open stores today (Easter Sunday) I found something that looked similar (dual level) to what I had but out of plastic and decided I could cut the 67mm level away. The result seems to be a snug fit with the 65mm part but being plastic the 3/8" drive part is too weak. Oh well. I don't see any seepage and it probably doesn't need to be torqued to exactly x Nm but I do want it good n tight and I don't think I am yet. So it's either NAPA if they have it or ordering one online.
But which is it, 65mm or 64mm?
