Clear Bra
I decided that I am going to invest in a clear bra. I did some research and found the clear bra can be washed and waxed the same as the rest of the car. Plexus is a good product to use on clear bras.
I did however have a question. Will the shine in the section of the car that has the clear bra, be noticeably different than the rest of the paint? Will the paint be damaged if you decided (for whatever reason) to remove the clear bra?
Not if you buy the highest quality clear bra you can and have it installed by someone who really knows what they are doing.
Nope.
Clear Automotive Protective Coating (A.K.A. Clear Bra):
Developed by the 3M Company, Scotchgard™ Paint Protection Film, (SGPPF6) 99.5% optically clear 8Mil (0.008-inch) film designed to reduce stone chipping and bug damage on painted surfaces. It’s a blend of acycloolefin, copolymer and a thermoplastic urethane, a tough, conformable material that is covered by a clear coat layer.
This rugged transparent material will not crack, shrink or peel over time and it resists yellowing, the film and clear coat layers contains a protection to counteract harmful ultraviolet (UV) and infrared (IR) radiation that can cause the surface to occlude (cloud) Testing from 3M reveals that the material will deflect road debris without film damage at up to 60MPH with the standard film. Mid-tone coloured cars, silver, reds, greens or gold’s, the film absolutely disappears into these colour (Product Specs http://www.armourfend.com/images/3M.pdf )
Ensure that there are no surface imperfections before installation. It is important to remember that paint protection film application is not considered to be a do-it-yourself project. For best results, professional application is recommended.
Clean and maintain its surface with ( Z-8™ Grand Finale Spray Seal) or a plastic cleaner (Plexus® Plastic Cleaner, Protectant and Polish) start at the centre and work outwards, do not use a foam pad / rotary buffer / abrasive compound on the plastic surface or detailer’s clay as it will cause micro-fine surface scratches.
To remove minor scratches in the film (, tape the edges of the auto mask when polishing the vehicles paint, use a high speed buffer (white foam pad only) and lightly glaze over the material. It is important not to apply a lot of pressure to the film as this may lead to burning of the surface. Use a Q-tip and some isopropyl alcohol to clean out the edge (See also 3M website- http://www.mmm.com)
Maintenance and Care- 1. To clean stains use a citrus based cleaner (P12S Total Auto Wash) polish the paint and the clear plastics separately, tape the edges with masking tape. It has a clear coat so it can be cared for like a clear coated paint; use Zaino or Klasse as they will dry ‘clear’. Use Z-14 Plastic Magic Cleaner & Polish™ or Plexus® Plastic Cleaner, Protectant and Polish for maintenance and to remove any finger marks / smudges (avoid the use of abrasives)
2. What can be done about wax build up along the seams and how can I avoid it?
Wax will leave a white line on the seam, it is recommended not to wax over the seams and wax the film and uncovered portions separately to keep from wax build-up. If you accidentally wax over the seam, just use a wet towel and rub it off. Another caution is to avoid buffing over the seams, which creates a noticeable wax line as well.
3. To remove ‘clouding’ from the paint under the clear bra; the suns heat or a hairdryer will remove it.
4. Removal -it is not difficult to remove, apply heat to a corner with a hair dryer (not a heat gun) and work slowly to avoid breaking / tearing the vinyl (like any applied vinyl, the longer it’s been applied the more difficult it will be to remove) work slowly and be patient. Detailer’s clay and /or 1:1 Isopropyl Alcohol / distilled water to clean any adhesive residue. Note: if the film is properly applied to a fully cured painted vehicle, it can be removed, usually in one piece, without damaging the paint surfaces beneath the film by pulling the film at an angle not straight up.
Information resource: http://www.automotivearticles.com/Clear_Bra_3M.shtml
Alternative products- a) As an optically clear product (recommended) http://www.invisiblepatterns.com
X-Pel UK Area Dealers- http://www.xpel.com/products/dealersearch-world.asp
