"check Engine" Light Is On
olegf
ES300, 98, 87K.
"Check engine" light is on. I checked the gas tank cap, it's
tight. Car runs good.
My mechanic read error code - PO135 "HO2S Heater Circut
Malfunction, Bank 1 Sensor 1".
It's $160 sensor + labor.
I wander if readings on non-Lexus equipment can be trusted, or I need to go to Lexus dealer for diagnostics?
Thanks.
Check the resistance between pins on the heating element of the sensor (pins 1 & 2 I think). At aft bank, near firewall, disconnect sensor and read there, I believe resistance should be between 6 and 11 ohms. I currently have same issue with the wife's, plan on changing tomorrow. I had same code and have open circuit.
