droppedlexus Posted September 20, 2006 Share Posted September 20, 2006 I have a 1993 gs300, my shifter is stuck in park....any ideas???? I have tried putting my foot on the brake, nothing seems to be working Quote Link to comment Share on other sites More sharing options...
Benjamin Tang Posted September 20, 2006 Share Posted September 20, 2006 i have a 2nd gen gs... there is a shift override slot where you stuff a key or screwdriver in the shift console... do you have one of those? Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted September 21, 2006 Author Share Posted September 21, 2006 yeah I found it....and it does allow me to shift gears...but once it's placed back in park it's stuck again????? Quote Link to comment Share on other sites More sharing options...
mehullica Posted September 21, 2006 Share Posted September 21, 2006 The shift interlock gets power the the brake light switch. Is the brake light fuse/circuit good? Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted September 25, 2006 Author Share Posted September 25, 2006 yeah the brake lights work, I don't know what to do at this point Quote Link to comment Share on other sites More sharing options...
Benjamin Tang Posted September 25, 2006 Share Posted September 25, 2006 you need to bring it into the mechanic asap. the override is only a temporary solution and may also fail and then you'll be permanently stuck. i remember reading somewhere of someone with this problem getting diagnosed for a some sort of shift interlock linkage that needed replacement. i can't find the post at the moment.... Quote Link to comment Share on other sites More sharing options...
1sikgs Posted September 25, 2006 Share Posted September 25, 2006 Look through your fuses. I have had this problem before with another car of mine. There is a fuse that controls the neutral safety switch. If that fuse if broken you will not be able to shift out of park. If there is still a problem after that, then the neutral safety switch might be bad. Quote Link to comment Share on other sites More sharing options...
GuyTelefunken Posted September 26, 2006 Share Posted September 26, 2006 Electrical diagram for the shift lock system. Check the fuses noted at the top. Shift_Lock.pdf Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted September 26, 2006 Author Share Posted September 26, 2006 you know I also have a post about my center console acting up.....I think these 2 issues may be related??? Quote Link to comment Share on other sites More sharing options...
1sikgs Posted September 26, 2006 Share Posted September 26, 2006 you know I also have a post about my center console acting up.....I think these 2 issues may be related??? you should definitely take a look at the fuses. there are times that a single fuse can control more than one operation. this could mean that the same fuse that is keeping your car from shifting is causing the problem with the center console Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted October 3, 2006 Author Share Posted October 3, 2006 you know what I don't have any brake lights?????? anybody know where the fuse is for it? Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted October 4, 2006 Share Posted October 4, 2006 i've seen this problem with many cars and a lot of the times the solenoid that works the shift lock on the gearshift. the main killer i've seen over the years is spilled drinks of one type or another. causes the plunger on the solenoid to stick. i've been able to clean a few. Quote Link to comment Share on other sites More sharing options...
droppedlexus Posted October 4, 2006 Author Share Posted October 4, 2006 bad fuse, fixed all problems.....thanks a million for all the help Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted October 4, 2006 Share Posted October 4, 2006 but why did the fuse blow? Quote Link to comment Share on other sites More sharing options...
1sikgs Posted October 4, 2006 Share Posted October 4, 2006 but why did the fuse blow? things happen. there could have been a small electrical surge. no matter the problems fixed. Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted October 5, 2006 Share Posted October 5, 2006 i guess i think different owning a repair facility. i would like to get to the bottom of the problem. i've never owned a car where a fuse burnt out for no reason. each to his own i guess. Quote Link to comment Share on other sites More sharing options...
