Geo Posted August 29, 2006 Share Posted August 29, 2006 2001 ES300. I just noticed (wifes car) that while driving the temperature gauge/needle does not move at all. I have driven it for 6 hours straight and the needle stays right at the bottom. No movement whatsoever. I know this can't be right since most cars the needle goes to mid range and goes up and down as you drive. What do I tell the tech to check ? Thanks, George Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 29, 2006 Share Posted August 29, 2006 It could be a couple of things, the gauge itself, the thermostat perhaps. Quote Link to comment Share on other sites More sharing options...
Geo Posted August 29, 2006 Author Share Posted August 29, 2006 SW: The car runs smooth as silk. No heating issues. No warning lights or the such. Would not a thermostat problem show up as a issue ? Could it be a sensor (if it has one ) ? Any other ideas ? I'd like not to sound like a imbecile when I take it in to lexus. George Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 29, 2006 Share Posted August 29, 2006 Probably the wiring to the gauge. If the sensor was dead, the ECU would throw a fit & stay in warm-up mode. You'd have no overdrive, and the engine wouldn't want to rev past... Say 4000rpm at all. Alias, check the wiring, the gauge & the sensor. Quote Link to comment Share on other sites More sharing options...
svarog Posted August 29, 2006 Share Posted August 29, 2006 My speedometer needle gets stuck sometimes, before you do anything try smacking it and see if it gets freed up. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted August 29, 2006 Share Posted August 29, 2006 I've never had it happen on a Lexus, but on my old Explorer the thermostat got stuck open, causing the engine to always run cool which caused the needle never to move up into the normal range. There were no other symptoms. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted August 30, 2006 Share Posted August 30, 2006 Turn the heat on and see if it is actually hot. If it is then it is either a specific temp sender for the gauge ( my civic has 3 one for the fan,ecu and dash separately). Or the gauge itself. Quote Link to comment Share on other sites More sharing options...
