Hello,
You should change TB @90,000.
Lasttime, at 130,000 TB was done. Now i have 210,000.
I like to change,
Timing belt + other belts
Water pump
2 Cam shaft seal
1 Crank shaft seal
Spark plug
How much money i should pay??
Can i use Toyota Camry V6 model parts?
Thanks in advance..
I would do a search since this comes up every 6 or so months. The big facture is where you live.Different parts of the country are more/less.
FYI, I padi $740 out the door at lexus (toytota, owned by same people was the same price). Other prices I got where $900 for water pump and TB and up to over 1,200 ( i Boston) for what I paid 740 (in western MA). In hartford CT it was almost 600 for TB alone.
Look around and call some places. HINT HINT. I know I did and it saved me some serious jingle.
Hello,
I like to change,
Water pump
2 Cam shaft seal
1 Crank shaft seal
Spark plug
Thanks in advance..
Just got mine done- Bill sitting in front of me
Water Pump $120.30
Timing Belt and Tensioner kit (includes seals) $243.72
Labor $285
Spark plugs replace (I bought my own and had them install) $165 (Labor only)
That is what I have in my Es300. The freaky weird part, off subject kind of is my gsxr1100 (1994) motorcycle has an NGK in the FSM AND denso #'s.
Are they connected (business wise)?
I received quote from my best mechenic $550
Includes: TB, other belts,Spark plug, Thermostate, 2 Cam seal, Crank shaft seal,
WP, Tensioner assemblies. all Toyota parts.
I think nobody can beat this price, unless you do it by your self.
+ $550 for 4 Michelin MXV4 Plus tires.
and i will good til 300,000
Love this car.........
Looks like a great price for the TB etc. My guess is he is making more $$$ on the tires.
Either way you both will be happy...which is a great thing! :)
I am buying tires from discount tires.
They are on sales for $125
$18 per tire he is charging for warranty.
$11 per tire for life time balance
$16 for four valve
+ tax total was ~$650
he is giving me $100 credit for my tires. I have same tires presently.\
it's 50,000 miles tires. i already put 55,000.
Thanks,
Finally,
I did drop my car today for following repair:
1. Timing belt + 2 Drive belts
2. Water pump
3. Tensioner and Pully
4. 2 Cam seal + 1 Crank Shaft seal
5. Spark Plug (Denso) + Wire
6. Thermostate + flush radiator
It will ready tomorrow evening for another 100,000.
Presently, my car has 210,000.
I am still using 5W30 Castrol Synth. Blend. I noticed that between oil change
i am using 1/2 Qts. Is this normal? Or change to 10W30?
Thanks,
yes
Hi,
I got the service done at toyota. I got tb, water pump, 2 cam shaft
seals,1 crank seal,and new drive belts. $647 out the door
Where did you get your service for $647 done at?
