camlex Posted August 22, 2006 Share Posted August 22, 2006 Hello, You should change TB @90,000. Lasttime, at 130,000 TB was done. Now i have 210,000. I like to change, Timing belt + other belts Water pump 2 Cam shaft seal 1 Crank shaft seal Spark plug How much money i should pay?? Can i use Toyota Camry V6 model parts? Thanks in advance.. Quote Link to comment Share on other sites More sharing options...
pearlwhite97ES Posted August 22, 2006 Share Posted August 22, 2006 Hi, I got the service done at toyota. I got tb, water pump, 2 cam shaft seals,1 crank seal,and new drive belts. $647 out the door Quote Link to comment Share on other sites More sharing options...
mburnickas Posted August 22, 2006 Share Posted August 22, 2006 I would do a search since this comes up every 6 or so months. The big facture is where you live.Different parts of the country are more/less. FYI, I padi $740 out the door at lexus (toytota, owned by same people was the same price). Other prices I got where $900 for water pump and TB and up to over 1,200 ( i Boston) for what I paid 740 (in western MA). In hartford CT it was almost 600 for TB alone. Look around and call some places. HINT HINT. I know I did and it saved me some serious jingle. Quote Link to comment Share on other sites More sharing options...
camlex Posted August 23, 2006 Author Share Posted August 23, 2006 Thank you. Which brand should i use for spark plug? Thanks, Quote Link to comment Share on other sites More sharing options...
rayder34 Posted August 23, 2006 Share Posted August 23, 2006 Hello, You should change TB @90,000. Lasttime, at 130,000 TB was done. Now i have 210,000. I like to change, Timing belt + other belts Water pump 2 Cam shaft seal 1 Crank shaft seal Spark plug How much money i should pay?? Can i use Toyota Camry V6 model parts? Thanks in advance.. Just got mine done- Bill sitting in front of me Water Pump $120.30 Timing Belt and Tensioner kit (includes seals) $243.72 Labor $285 Spark plugs replace (I bought my own and had them install) $165 (Labor only) Quote Link to comment Share on other sites More sharing options...
Toysrme Posted August 23, 2006 Share Posted August 23, 2006 NGK, or Denso ONLY. Quote Link to comment Share on other sites More sharing options...
camlex Posted August 23, 2006 Author Share Posted August 23, 2006 Thanks, I will go with Denso. Have a good day. Quote Link to comment Share on other sites More sharing options...
mburnickas Posted August 23, 2006 Share Posted August 23, 2006 That is what I have in my Es300. The freaky weird part, off subject kind of is my gsxr1100 (1994) motorcycle has an NGK in the FSM AND denso #'s. Are they connected (business wise)? Quote Link to comment Share on other sites More sharing options...
camlex Posted August 31, 2006 Author Share Posted August 31, 2006 I received quote from my best mechenic $550 Includes: TB, other belts,Spark plug, Thermostate, 2 Cam seal, Crank shaft seal, WP, Tensioner assemblies. all Toyota parts. I think nobody can beat this price, unless you do it by your self. + $550 for 4 Michelin MXV4 Plus tires. and i will good til 300,000 Love this car......... Quote Link to comment Share on other sites More sharing options...
mburnickas Posted August 31, 2006 Share Posted August 31, 2006 Looks like a great price for the TB etc. My guess is he is making more $$$ on the tires. Either way you both will be happy...which is a great thing! :) Quote Link to comment Share on other sites More sharing options...
camlex Posted August 31, 2006 Author Share Posted August 31, 2006 I am buying tires from discount tires. They are on sales for $125 $18 per tire he is charging for warranty. $11 per tire for life time balance $16 for four valve + tax total was ~$650 he is giving me $100 credit for my tires. I have same tires presently.\ it's 50,000 miles tires. i already put 55,000. Thanks, Quote Link to comment Share on other sites More sharing options...
camlex Posted September 13, 2006 Author Share Posted September 13, 2006 Finally, I did drop my car today for following repair: 1. Timing belt + 2 Drive belts 2. Water pump 3. Tensioner and Pully 4. 2 Cam seal + 1 Crank Shaft seal 5. Spark Plug (Denso) + Wire 6. Thermostate + flush radiator It will ready tomorrow evening for another 100,000. Presently, my car has 210,000. I am still using 5W30 Castrol Synth. Blend. I noticed that between oil change i am using 1/2 Qts. Is this normal? Or change to 10W30? Thanks, Quote Link to comment Share on other sites More sharing options...
anthonyiez Posted September 13, 2006 Share Posted September 13, 2006 That is what I have in my Es300. The freaky weird part, off subject kind of is my gsxr1100 (1994) motorcycle has an NGK in the FSM AND denso #'s. Are they connected (business wise)? yes Quote Link to comment Share on other sites More sharing options...
ratso Posted September 27, 2006 Share Posted September 27, 2006 Hi, I got the service done at toyota. I got tb, water pump, 2 cam shaft seals,1 crank seal,and new drive belts. $647 out the door Where did you get your service for $647 done at? Quote Link to comment Share on other sites More sharing options...
