I cannot close the center air vents completely. The knobs don't turn all the way down to close the vents, they stop halfway, so air keeps blowing through. Other vents close fine. Is this normal?
Thanks.
Thanks.
Mine do this as well. I believe it is normal.
There's a separate knob for opening and closing. The slats themselves are only for directing the flow.
I realized that once I got into the car after my last post!
The center vents on my ES cannot be closed at all...
I never understood why Lexus didn't make them closable like the side ones. Normally, I drive alone and just point them to the passenger seat.
why have the air con on at all if your going to turn them off?
you must have it on for some other passenger then...in which you point it to their direction
