gjneko Posted June 24, 2006 Posted June 24, 2006 I cannot close the center air vents completely. The knobs don't turn all the way down to close the vents, they stop halfway, so air keeps blowing through. Other vents close fine. Is this normal? Thanks.
lambobaby1218 Posted June 24, 2006 Posted June 24, 2006 I cannot close the center air vents completely. The knobs don't turn all the way down to close the vents, they stop halfway, so air keeps blowing through. Other vents close fine. Is this normal? Thanks. Mine do this as well. I believe it is normal.
bartkat Posted June 25, 2006 Posted June 25, 2006 There's a separate knob for opening and closing. The slats themselves are only for directing the flow.
SW03ES Posted June 25, 2006 Posted June 25, 2006 The center vents on my ES cannot be closed at all...
lambobaby1218 Posted June 25, 2006 Posted June 25, 2006 There's a separate knob for opening and closing. The slats themselves are only for directing the flow. I realized that once I got into the car after my last post!
obsidianr Posted June 26, 2006 Posted June 26, 2006 The center vents on my ES cannot be closed at all... I never understood why Lexus didn't make them closable like the side ones. Normally, I drive alone and just point them to the passenger seat.
Rx330driver Posted June 26, 2006 Posted June 26, 2006 why have the air con on at all if your going to turn them off? you must have it on for some other passenger then...in which you point it to their direction
bartkat Posted June 27, 2006 Posted June 27, 2006 I checked my IS350 this afternoon and the little roller knobs will close the center vents off completly.
