wwest Posted June 20, 2006 Share Posted June 20, 2006 Lexus salesman just informed me that the Camry Hybrid will not be used as a Lexus ES hybrid base because Lexus drivers are more POWER oriented, example being the RX400h. With 700 volts available I would think that that a blower type supercharger would be quite viable to raise the Atkinson I4's HP/Torque into a more acceptable "Lexus" range. The higher the drive frequency used means the SC's AC drive motor size at a given HP can be much smaller than with a lower frequency. And the SC could just "idle" along, very little power consumption, supplying only atmospheric pressure at the inlet unless/until WOT is used. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 20, 2006 Share Posted June 20, 2006 I'd be utterly shocked. Quote Link to comment Share on other sites More sharing options...
wwest Posted June 20, 2006 Author Share Posted June 20, 2006 I'd be utterly shocked. But pleased..........?? Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 22, 2006 Share Posted June 22, 2006 Eh, I wouldn't be interested in one if it was slow. Its a luxury car, if I wanted economy I'd buy a Camry hybrid.I would buy an ES400h in a heartbeat. Quote Link to comment Share on other sites More sharing options...
wwest Posted June 22, 2006 Author Share Posted June 22, 2006 Eh, I wouldn't be interested in one if it was slow. Its a luxury car, if I wanted economy I'd buy a Camry hybrid.I would buy an ES400h in a heartbeat. Unless my math is whacko the Camry hybrid is already "faster" that your ES300, maybe even faster than the ES350. The Camry hydrid ICE produces 147HP and the electrics kick in another ~150HP. Overall torque is in the range of 350 ft/lbs. Adding an SC would undoubtedly kick in another 15% from the ICE while likely improving the highway cruise FE substantially. Quote Link to comment Share on other sites More sharing options...
SW03ES Posted June 22, 2006 Share Posted June 22, 2006 Its not faster than my ES300, even if it were it would still be slow, my ES300 does not have enough power to motivate this heavy a car. The Camry Hyrbid has TOTAL 187hp and 199lb ft of torque and does 0-60 in 7.7 seconds. My ES300 by comparison has 210hp and 220 lb ft of torque and does 0-60 in 8.1 seconds. The ES350 has 272hp and 254 lb ft of torque with a 0-60 time of 7.1 seconds Cites: Camry Hybrid Specs: http://www.toyota.com/images/vehicles/2007/camry/specs.pdf Camry Hyrbid Performance: http://www.caranddriver.com/shortroadtests...mry-hybrid.html 2003 ES300 Specs: http://autos.msn.com/research/vip/spec_eng...20300&trimid=-1 2003 ES300 Performance: http://autobuyguide.com/2003/12-aut/lexus/...iews/index.html 2007 ES350 Specs: http://autos.msn.com/research/vip/spec_eng...20350&trimid=-1 2007 ES350 Performance: http://www.edmunds.com/insideline/do/Drive...87/pageId=69243 Quote Link to comment Share on other sites More sharing options...
wwest Posted June 23, 2006 Author Share Posted June 23, 2006 Its not faster than my ES300, even if it were it would still be slow, my ES300 does not have enough power to motivate this heavy a car. The Camry Hyrbid has TOTAL 187hp and 199lb ft of torque and does 0-60 in 7.7 seconds. My ES300 by comparison has 210hp and 220 lb ft of torque and does 0-60 in 8.1 seconds. The ES350 has 272hp and 254 lb ft of torque with a 0-60 time of 7.1 seconds Cites: Camry Hybrid Specs: http://www.toyota.com/images/vehicles/2007/camry/specs.pdf Camry Hyrbid Performance: http://www.caranddriver.com/shortroadtests...mry-hybrid.html 2003 ES300 Specs: http://autos.msn.com/research/vip/spec_eng...20300&trimid=-1 2003 ES300 Performance: http://autobuyguide.com/2003/12-aut/lexus/...iews/index.html 2007 ES350 Specs: http://autos.msn.com/research/vip/spec_eng...20350&trimid=-1 2007 ES350 Performance: http://www.edmunds.com/insideline/do/Drive...87/pageId=69243 Okay, glad to see my math wasn't whacko, just missed the fact that the traction battery can only put out 40HP peak. Anyone know why they would use an AC synchronous motor of 150HP rating if the battery is only good to 40HP..?? Quote Link to comment Share on other sites More sharing options...
