Black on Black Posted June 16, 2006 Share Posted June 16, 2006 So I searched the forum and figured it would be best to simply clean my switches to get them all working again. While doing so, the power window lock spring popped out causing the white plastic housing, a gold clip, and what looks like a staple to come un-done. Has anybody had this happen? I'm not quite sure how it all goes back together. I should just buy the full service manual for this car! Quote Link to comment Share on other sites More sharing options...
laserron Posted June 23, 2006 Share Posted June 23, 2006 I have a copy of the manual. Does not go to that level of detail. Tells in great detail how to test the switches. If it is one of the switches on the drivers door perhaps, you could carefully take one of the other switches apart and see where the pieces go. Good luck LaserRon Quote Link to comment Share on other sites More sharing options...
Black on Black Posted June 24, 2006 Author Share Posted June 24, 2006 LaserRon, Thanks for looking over that for me. I figured out that it is on windowlock mode now. I can only open and shut the drivers side door. I'll just have to figure out where the button needs to contact to not be in power window lock mode as a temp fix until I buy a new unit. Quote Link to comment Share on other sites More sharing options...
