Is it plastic or what is it made out of?
Sorry to burst your bubble guys but it looks like it's plastic. I just swapped out my ashtray for the JDM optional one.
It that's a Lexus OEM part, give it the burn test and see if it's wood. :D
The wood trim on every lexus is actually real wood even though it may be only a few mm thick. Just as someone said earlier there is a lot of lacqer on it that makes it look like plastic. And it is in fact made by Yamaha (they make pianos) and every piece in the car is supposed to match.
JDM Optional one!? :unsure:
It absolutely is real, all Lexus use real wood. It is however a thin veneer bonded to a plastic backing. This is obviously cheaper and it keeps the wood from expanding and contracting with the elements. All carmakers do this.
You actually can see where the veneer ends and the plastic begins in clubfoot's pics.
Absolutely 100% real wood.
In fact, check out Lexus' FAQ on cleaning.
Since it's real wood, they recommend a cleaner like pledge.
They say to spray it on a soft cloth to clean, and not to spray the cleaner directly onto the wood, since excessive amounts could cause the bonding material to break down.
It's a very thin veneer, but it is real wood.
Sidenote: Acura uses 100% fake wood in every model except the RL.
Lexus uses real wood in all of their models.
Well, you can use anything that you can use on plastic. I use Plexus clear plastic cleaner, its coated under such a thick plastic shell.
I like the wood look and all (prefer the aluminum look more) but it fingerprints really easy. Its like I clean it and 2 days later it’s all greasy looking. Its like I went to KFC and took the drumstick and started rubbing it on the wood.
LMAO! :lol:
try using something used to clean plastic like Plexus or Novus, or something used to clean wood like Pledge.
  • 3 weeks later...
they put on a healthy slab of lacquer to protect the finish
Yeah, and it scratches real easy. In a couple of years it's not going to look very good. :( :angry:
Good visual--Thats funny!
I've got a 5 year old RX300 with 105k miles and the plasticky wood still looks the same. Not scratched. Maybe a bit "drumsticky" though...
It can also be polished, thats one good thing about the lacquer. Mine still looks new after 70k, my dad's 98's wood still looked new after 160k too.
