akkuma2k Posted May 2, 2006 Share Posted May 2, 2006 i went to have my plugs and wires changed and the mechanic told me that for my car the plugs dont have to be gapped because they are pre-gapped i told him hold on and then i called a friend who said no way! i ended up just waiting till i consult with the people who know my car best! can one of you playas help me on this one. :cries: Quote Link to comment Share on other sites More sharing options...
monarch Posted May 2, 2006 Share Posted May 2, 2006 Mechanic is right IF (and that's a big IF), you buy genuine Toyota PQ20R spark plugs from a Toyota or Lexus dealer. They are cheaply priced at 1sttoyotaparts.com. If you order from 1sttoyotaparts.com or your neighborhood Toyota dealer, just tell the salesperson you have a '93 Camry V6 and want Toyota part# 90919-01127 spark plugs You can also order genuine Toyota spark plug wires cheaply at 1sttoyotaparts.com for your '93 3VZ-FE V6. They are Toyota part#90919-21519. The distributor cap part# is 19101-62050 and the distributor rotor part# is19102-62030. Your mechanic likely only carrys Ford and Chevy quality aftermarket parts. If that's all you want then let the mechanic use his parts. If you let the mechanic use his own parts you may notice engine power seems softer and mushier than before and fuel economy is off a bit. Quote Link to comment Share on other sites More sharing options...
Lexusfreak Posted May 2, 2006 Share Posted May 2, 2006 Most laser platinum & Iridium plugs come already 'pre-gapped' so your mechanic was correct. B) All one has to do is use one of those gap tools mechanics have to prove it. B) Quote Link to comment Share on other sites More sharing options...
mburnickas Posted May 2, 2006 Share Posted May 2, 2006 Most laser platinum & Iridium plugs come already 'pre-gapped' so your mechanic was correct. B) All one has to do is use one of those gap tools mechanics have to prove it. B) Sparkplug gaping only work on non-Iridium spark plugs (gapped at manufacture). At least when I got my Denso ones they were warnings all over not to gap them since you will break the tips. I get my plugs from sparkplugs.com. The Lexus/Toyota online places are too high for these items. Quote Link to comment Share on other sites More sharing options...
akkuma2k Posted May 2, 2006 Author Share Posted May 2, 2006 thanx guys for your help. Quote Link to comment Share on other sites More sharing options...
Toysrme Posted May 2, 2006 Share Posted May 2, 2006 Some plugs come pre-gapped. Both NGK & Denso sell pre-gapped plugs for the engine, in every model of plug they sell. They also sell un-gapped plugs that are at the "traditional" .44 plug gap. All of the plugs that are refferanced to the specific engine *are* pre-gapped. If you look your car up, you'll get returned the right plug with a pre-gap. Quote Link to comment Share on other sites More sharing options...
abrarcool Posted May 2, 2006 Share Posted May 2, 2006 I had denso put in my 94 and they were pre gapped i made sure by checking the gaps myslef Quote Link to comment Share on other sites More sharing options...
steviej Posted May 3, 2006 Share Posted May 3, 2006 pre-gapped or not, I always check them. You never know what happened in the store room, in transit or with the initial gapping. I don't trust blind faith and it only takes a second to check. steviej Quote Link to comment Share on other sites More sharing options...
Nau Posted May 4, 2006 Share Posted May 4, 2006 About the plugs - what BRAND (aside from Toyota - is it NGK by the way?) is good for our Lexus? pre-gapped or not, I always check them. You never know what happened in the store room, in transit or with the initial gapping. I don't trust blind faith and it only takes a second to check. steviej Right on, Steve! Quote Link to comment Share on other sites More sharing options...
azmalu Posted September 21, 2006 Share Posted September 21, 2006 hey on 1mzfe 3rd gen gap is .42 right....? Quote Link to comment Share on other sites More sharing options...
Toysrme Posted September 21, 2006 Share Posted September 21, 2006 IDk man check the repair manual. http://lextreme.com/v6/viewtopic.php?t=22&...440744a73e7bf8f Seems like they all run .44 stock. Quote Link to comment Share on other sites More sharing options...
azmalu Posted September 21, 2006 Share Posted September 21, 2006 pregap from autozone was .42 but i checked sparkplugs.com or whatever the link from a similar thread an its .44 so i better check mined againt to make sure... Quote Link to comment Share on other sites More sharing options...
