914lps Posted April 14, 2006 Share Posted April 14, 2006 OK folks, your thoughts on this. Getting ready to pull the tranny pan for the first time in 140,000 miles. I will also flush and fill the trany. Should I just clean the "oil strainer" part #35330-50010, or replace it? Quote Link to comment Share on other sites More sharing options...
wwest Posted April 14, 2006 Share Posted April 14, 2006 OK folks, your thoughts on this. Getting ready to pull the tranny pan for the first time in 140,000 miles. I will also flush and fill the trany. Should I just clean the "oil strainer" part #35330-50010, or replace it? I would normally say replace it only if it is clogged and would need to be pressure cleaned, but at 140,000 miles your strainer has earned a rest. Quote Link to comment Share on other sites More sharing options...
Shadow Posted April 14, 2006 Share Posted April 14, 2006 The metal screen can be clean and reuse. Replace if you don't want to take up the chore. Quote Link to comment Share on other sites More sharing options...
monarch Posted April 15, 2006 Share Posted April 15, 2006 The metal mesh filter screen is pretty tough and cleans up by spraying with brake cleaner. The screen only needs to be replaced if it has become accidentally torn due to rough handling. There are magnets in the bottom of the transmission oil pan too. Like the metal filter screen, the magnets do not wear out ...they merely need to be cleaned up using brake cleaner and some paper towels. I forgot to mention that if your filter screen is attached to the transmission using a gasket, you must buy a new filter gasket from a Toyota or Lexus dealer. I can't remember if the screen on the LS transmission has a gasket or not. Quote Link to comment Share on other sites More sharing options...
sha4000 Posted April 16, 2006 Share Posted April 16, 2006 mine didnt have a gasket Quote Link to comment Share on other sites More sharing options...
ko90ls Posted April 16, 2006 Share Posted April 16, 2006 No Gasket, No Flush (they kill LS trannies, personal expirence :chairshot: ) clean the filter even toyota will tell you they are reuseable, fill with two quarts of T4. also make sure you've got the FIPG. Good Luck! Quote Link to comment Share on other sites More sharing options...
