Navigation Screwed Up.......
i have GS 400 i buy it from usa model 2000 ....
i am from bahrain and i want to change the Gps map to bahrain maps
i want more information about this think ... i chek my luxes computer and it need
hardisk drive to put the nivigation softwar on it ... plaes if any budy have this softwar
or informaiton hlpe me ....
thanks for all
MY EMAIL : alhsoon1@hotmail.com
  • Replies 54
  • Created
  • Last Reply
Top Posters In This Topic
disconnecting the battery, removing the Disk player (ECU?) from underneath the passanger seat and disconnecting the battery inside the dvd drive worked for me. LX470. used a small flat head to break the solder to the battery lead, then taped it back on. i was too chicken to solder in there. if the connection comes loose, ill solder it
How long did you disconnect the battery?
  • 11 months later...
I did this twice.
First time I opened up the rear compartment and took out the navigation ECU, and took it apart to do the reset, and it worked.
Second time I simply disconnected the car battery for over night, and it also resetted. Bad part is, all other settings were lost as wel.
I did this twice.
Thanks for your reply. It's been a while since I checked this forum last time. Will try this weekend.
Thanks again!!
