Sweet95LS400 Posted March 30, 2006 Share Posted March 30, 2006 I have scheduled to take my 95 LS in for the 90k service tomorow at the Lexus dealer. The following items will be completed as per their recommendations and the 90k service manual by Lexus. - Replace Timing Belt - Replace Water Pump - Replace Crank Seal - Replace Cam Seals - Change/flush brake fluid - Change/flush coolant - Replace pulley/tensioner - Engine oil/filter service - Change spark plugs - Change/flush transmission fluid - Aim headlamps/foglamps Problems to be looked at outside of the 90k service: - Firm 2-3 shift - Occassional low idle/idle bouncing - Wiper alignment (clunking noise when they are on) - Vibration from the drivetrain when accelerating with a car load of people (already replaced transmission mount, I am thinking it might be another mount somewhere else in the rear end) Anyone else have any items to be checked or serviced at this time. Everything else is working as designed. Quote Link to comment Share on other sites More sharing options...
sv7887 Posted March 30, 2006 Share Posted March 30, 2006 I have scheduled to take my 95 LS in for the 90k service tomorow at the Lexus dealer. The following items will be completed as per their recommendations and the 90k service manual by Lexus. - Replace Timing Belt - Replace Water Pump - Replace Crank Seal - Replace Cam Seals - Change/flush brake fluid - Change/flush coolant - Replace pulley/tensioner - Engine oil/filter service - Change spark plugs - Change/flush transmission fluid - Aim headlamps/foglamps Problems to be looked at outside of the 90k service: - Firm 2-3 shift - Occassional low idle/idle bouncing - Wiper alignment (clunking noise when they are on) - Vibration from the drivetrain when accelerating with a car load of people (already replaced transmission mount, I am thinking it might be another mount somewhere else in the rear end) Anyone else have any items to be checked or serviced at this time. Everything else is working as designed. How about a Change/Flush of the Power Steering Fluid..I never did this and paid $$$ to replace the P/S Pump, High Pressure hose and Rack... Hope that helps, Sam Quote Link to comment Share on other sites More sharing options...
bicol-ini Posted March 30, 2006 Share Posted March 30, 2006 be prepared to shell out some good amount of $$$$$, some of them you can do if you just have the patience and a little of mechanical ability save you some for the big ones in which you dont have a choice, good luck Quote Link to comment Share on other sites More sharing options...
Sweet95LS400 Posted April 6, 2006 Author Share Posted April 6, 2006 Well I just got the car back from both the 90k service and also the water pump/timing belt change. I am very happy to say that the car runs much better. I thought it ran great before, but it seems to have more pep now and I definately noticed better gas mileage on the way home from the dealer (about a 2 hour trip). Thanks to everyone for their input. Quote Link to comment Share on other sites More sharing options...
nc211 Posted April 6, 2006 Share Posted April 6, 2006 Sweet, look on your invoice,did they put that BK44 additive in the car? Well I just got the car back from both the 90k service and also the water pump/timing belt change. I am very happy to say that the car runs much better. I thought it ran great before, but it seems to have more pep now and I definately noticed better gas mileage on the way home from the dealer (about a 2 hour trip). Thanks to everyone for their input. Quote Link to comment Share on other sites More sharing options...
Sweet95LS400 Posted April 6, 2006 Author Share Posted April 6, 2006 It doesnt say exactly what the product was that they added. It just says fuel system and intake cleaning. Quote Link to comment Share on other sites More sharing options...
Sweet95LS400 Posted April 8, 2006 Author Share Posted April 8, 2006 I will be taking the car back in a week or two, I need to have my drivers and passenger side front seat belts looked at, they dont retract very well anymore. Sometimes you have to hand feel them back into the reel. Quote Link to comment Share on other sites More sharing options...
sapper_daddy Posted April 10, 2006 Share Posted April 10, 2006 hey i am having the same problems with my seat belts so let me know what you come up with, i thought about replacing them but i figured it really isn't too big of deal yet as they do retract and hold some tension. but it's important enough to be concerned about a fix in the future Quote Link to comment Share on other sites More sharing options...
Sweet95LS400 Posted April 10, 2006 Author Share Posted April 10, 2006 I have contacted Lexus about this, the dealer is going to inspect them and see what needs to be replaced. At that time Lexus may or may not assist with the replacement parts and labor. I did mention to them that on my Honda's the seatbelts and their components were covered for the life of the car. Quote Link to comment Share on other sites More sharing options...
blake918 Posted April 10, 2006 Share Posted April 10, 2006 I will be taking the car back in a week or two, I need to have my drivers and passenger side front seat belts looked at, they dont retract very well anymore. Sometimes you have to hand feel them back into the reel. This seems to be fairly common. I know some members persuaded Lexus in to changing their belts for free. I had a Lexus shop in Dallas change my driver's side belt (before I knew you could corner Lexus in to it) for something like $200 or $250. I travel alone mostly as did the PO of my car, so the driver's belt was the only defective one in my car...I'd actually have to feed it back in the the tensioner when I'd get out of the car. It's great to have a seatbelt that works! Quote Link to comment Share on other sites More sharing options...
dcfish Posted April 10, 2006 Share Posted April 10, 2006 I will be taking the car back in a week or two, I need to have my drivers and passenger side front seat belts looked at, they dont retract very well anymore. Sometimes you have to hand feel them back into the reel. This seems to be fairly common. I know some members persuaded Lexus in to changing their belts for free. I had a Lexus shop in Dallas change my driver's side belt (before I knew you could corner Lexus in to it) for something like $200 or $250. I travel alone mostly as did the PO of my car, so the driver's belt was the only defective one in my car...I'd actually have to feed it back in the the tensioner when I'd get out of the car. It's great to have a seatbelt that works! Might help. seatbelt_cleaning_lexus.pdf Quote Link to comment Share on other sites More sharing options...
