2001 Rx300 Battery Died - But How Do I Move The Car?
rockhead
The battery on my 2001 RX 300 died. Here's the problem - The car is in my driveway and is blocking my other car that's operable. I wanted to push the Lexus out of the way, however, I can't get it out of "park" to be able to move it. It won't budge from "Park" mode.
Any clues on how I can shift the car out of "Park" to get it out of the way?
Thanks so much!!
If you look at this picture you can see it... There's a small black plastic cover an inch or so above the "P" on the center console near the shifter.
If you lift this plastic piece off (with a flat head screw driver) you will be able to "push" (i think) something down that will allow you to put it in "N" It's all in the manual.
