Automatic Transmission Fluid
lefty, you have to specify which gs you have! 1st or 2nd gen gs as they have different tranny's? i think 1st gen gs uses dexron type fluid which have compatible synthetic for that type. while the 2nd gen "98+" gs uses toyota type t-iv fluid. i've tried to find a compatible fluid for the type t-iv but with no luck!!! well, hope this helped a bit!!!!
:D :D :D i use redline syn in my tran 98gs300 always have and always will i also use NEO syn for my motor oil 5w 30 in the winter and 10w in the summer the best , I also use evans waterless coolant year round -boils at 350 and gells at 40 below.
great stuff all around
dc :cheers:
