mig25 Posted July 25, 2003 Share Posted July 25, 2003 Here are some useful information I found in my repair manual. 1990/1991 LS400 Most of you folks already know all of this, but I will post anyway. Thanks. ATF -(Automatic Transmission Fluid) TYPE T- II OR EQUIVALENT CAPACITY 2.0 QTS (1.9 LITERS) BRAKE FLUID - FMVSS #116 DOT 3 OR SAE J1703 FOR VEHICLES WITH TRACTION CONTROL, IDLE ENGINE WHILE POURING FLUID IN TO RESERVOIR. COOLING SYSTEM 11.2 QTS (10.6 LITERS )(DEXCOOL ETHYLENE-GLYCOL 50/50 WATER MIX.) ENGINE OIL 5.3 QTS (5 LITERS) DIFFERENTIAL OIL 1.4 QTS (1.3 LITERS) AMBIENT TEMPERATURE MORE THAN 0 DEGREES F (-18 C) -SAE 90 API GL-5 LESS THAN 0 DEGREES F ( -18C) SAE 80 OR 80W-90 API GL-5 POWER STEERING FLUID - DEXRON-IIE ATF WHEN ADDING POWER STEERING FLUID, BECAREFUL NOT TO SPILL, ALTERNATOR IS BENEATH IT. WRAP THE RESERVOIR WITH A TOWEL JUST IN CASE. SERIOUS DAMAGE COULD OCCOUR IF ALTERNATOR GETS WET WITH ATF. FUEL TANK 22.5 GALLONS (85 LITERS) TIRE PRESSURE: 1990-1992 ( 15 x 6.5" ) - P205/65R-15 94V NORMAL LOAD - 30PSI SPARE TIRE - 36 PSI WHEEL LUGS TIGHTENING - 76 ft lbs ( 103 N.m) AIR CONDITIONING 1990 R12 REFRIGERANT CAPACITY -37.5 Oz CAPACITIES ARE RECOMENDED OR CALCULATED LEVELS. ALWAYS USE DIPSTICK IF AVAILABLE TO MEASURE LEVEL. ENGINE OIL MAX TEMP - LESS THAN 100 DEGREES F (38 C) -SAE 5W-30 API SH/CD MINIMUN TEMP - MORE THAN 0 DEGRRES F ( -18C) SAE 10W-30 API SH/CD SOURCE - maintenance info article, cd repair manual for LS400 1990 Mitchell repair Information If you need me to look up something in my manual feel free to sent an email , I will gladly provide the information. welgaby@msn.com Quote Link to comment Share on other sites More sharing options...
