dj77 Posted January 4, 2006 Posted January 4, 2006 Hello! I am looking for the step-by-step instructions with pics included on how to replace the front headlight on an ES300. I saw the directions about a year ago for a 1997 ES300 and cannot seem to locate them anymore?
SteveyG Posted January 4, 2006 Posted January 4, 2006 I'd also like to know if anyone can give good instructions for adjusting the headlights on my '95 ES 300. (Yes, I did a keyword "search" and didn't come across this.) It looks very accessible, and I noticed the little bubble level window, the screws, etc., but I don't want to "assume" and screw up the mechanism. Is there a manual I can get that would cover some of these basic maintenance and adjustment things? The owner's manual doesn't cover that stuff. Since I'm upgrading to Silver Star low beams, do I need to point them lower? Any other advice on installing Silver Stars (other than not touching the bulb with bare fingers)? -SG
Toysrme Posted January 4, 2006 Posted January 4, 2006 dj77 download the '98 FSM I posted. SteveyG download the '93 FSM I posted. One screw goes up & down, one screw goes left & right. No, silverstars will not put enough light on the road for you to need to point them down below the spcification. You shouldn't be hitting more than about halfway up the average trunk. That does not mean your headlights are aligned & not blinding people right now, or that your headlights are low, or off center. At 20' the beam cut-off should be the same height off the ground as the headlights.
dj77 Posted January 4, 2006 Author Posted January 4, 2006 Sorry, TOYSRME....new member here! Where exactly is the FSM?
Toysrme Posted January 4, 2006 Posted January 4, 2006 S ok, Factory Service Manual. I think somebody stickied it. (Thanks whoever LoL!)
kcpth Posted January 4, 2006 Posted January 4, 2006 It was Toy's Xmas gift to all of us. Thanks again Toys. :P http://us.lexusownersclub.com/forums/index...showtopic=26449
dj77 Posted January 4, 2006 Author Posted January 4, 2006 These are AWESOME! I don't see the FSM for the 1998 (which is my vehicle year). But I'm assuming I could find headlight replacement under the 1997 FSM?
mburnickas Posted January 4, 2006 Posted January 4, 2006 These are AWESOME! I don't see the FSM for the 1998 (which is my vehicle year). But I'm assuming I could find headlight replacement under the 1997 FSM? yup
justin97 Posted January 4, 2006 Posted January 4, 2006 These are AWESOME! I don't see the FSM for the 1998 (which is my vehicle year). But I'm assuming I could find headlight replacement under the 1997 FSM? yup headlight are easy to get out remove the black top piecce that covers the whole front. remove the corner and under the corner are two 10mm bolts and just one more 10mm bolt on top of the headlight and pull it out.
SteveyG Posted January 9, 2006 Posted January 9, 2006 Toys - Thanks for the FSMs! It took me awhile to get them unzipped, but WOW! is this valuable info. for owners. Thanks!!! -SG
pmopmo Posted January 11, 2006 Posted January 11, 2006 Toys - Thanks for the FSMs! It took me awhile to get them unzipped, but WOW! is this valuable info. for owners. Thanks!!! -SG how did you unzip it. I have been trying for days and get nowhere. Please help. thanks. pmopmo
Toysrme Posted January 11, 2006 Posted January 11, 2006 http://us.lexusownersclub.com/forums/index...howtopic=26449# Have fun!
