davej Posted December 17, 2005 Share Posted December 17, 2005 Check engine and TRAC off lights on, codes P2017 & p0402 reported. Hi, These codes related to the same issue I hope? Thanks for any advice. Dave Quote Link to comment Share on other sites More sharing options...
kashife Posted December 17, 2005 Share Posted December 17, 2005 Check engine and TRAC off lights on, codes P2017 & p0402 reported. Hi, These codes related to the same issue I hope? Thanks for any advice. Dave Hello, Dave what year is your car? I got a 98 es 300 and I got the engine light on also, but cant figure out the problem is. Quote Link to comment Share on other sites More sharing options...
SKperformance Posted December 17, 2005 Share Posted December 17, 2005 search results for p0402 Type the other code into the search for more answers. get the code read at any parts store for free. Quote Link to comment Share on other sites More sharing options...
davej Posted December 18, 2005 Author Share Posted December 18, 2005 The ES 300 is a 98'. Having searched for the p0402 code as suggested, it seems it may be related to the egr valve. I will continue to focus on this egr valve. Where is it? How do i clean it? Thanks! Quote Link to comment Share on other sites More sharing options...
davej Posted December 19, 2005 Author Share Posted December 19, 2005 I would like to add that yesterday I cleared the check engine light and trac-off lights. I then let the car run for some time with the lights staying off. I noted that when I accelerated hard the car stumbled. At this point, the check engine light and "trac off" light came on. So, it appears that the egr sensed rich fuel from the stumble and reported back? So is it true to say that the egr valve is likely doing its job and the car is just running bad? Thanks for reviewing this. Dave Quote Link to comment Share on other sites More sharing options...
