mikek753 Posted December 6, 2005 Share Posted December 6, 2005 hello, Any instructions / links about replacing air filter are very welcome Quote Link to comment Share on other sites More sharing options...
mburnickas Posted December 6, 2005 Share Posted December 6, 2005 hello,Any instructions / links about replacing air filter are very welcome ← I would put instructions need for XX car, XXX year. No clue on what you need. Quote Link to comment Share on other sites More sharing options...
mikek753 Posted December 6, 2005 Author Share Posted December 6, 2005 it's for Car Model:04 ES330 SD thanks. Quote Link to comment Share on other sites More sharing options...
steviej Posted December 7, 2005 Share Posted December 7, 2005 I would put instructions need for XX car, XXX year. No clue on what you need. ← mburn, I assume he is referring to the one is listed under his name in the profile. mikek753, use a 10mm socket on a long extension to remove the two bolts on two of the corners of the air box. On the back side of the air box is a bracket that holds some sort vacuum device. There is a philips screw that holds the bracket to the air box. The cover of the air box will pivot higher if the bracket is removed. Use a magnatized screwdriver so that you don't drop the screw into the abyss of the engine. Once the bracket is free (you need not remove or undo what the bracket is holding) and the two 10mm bolts are undone, you should be able to lift the cover up high enough to slide the air filter out and slide the new one in. Pay close attention to the orientation of the filter. Look for indents, patterns and labels or arrows that say front or flow. Once the new one is in, lower the cover, resecure the bracket and the 10mm bolts. you are done. steviej Quote Link to comment Share on other sites More sharing options...
JPB4999 Posted November 6, 2006 Share Posted November 6, 2006 Is this the same for the 2005 ES-330? Thanks. I would put instructions need for XX car, XXX year. No clue on what you need. ← mburn, I assume he is referring to the one is listed under his name in the profile. mikek753, use a 10mm socket on a long extension to remove the two bolts on two of the corners of the air box. On the back side of the air box is a bracket that holds some sort vacuum device. There is a philips screw that holds the bracket to the air box. The cover of the air box will pivot higher if the bracket is removed. Use a magnatized screwdriver so that you don't drop the screw into the abyss of the engine. Once the bracket is free (you need not remove or undo what the bracket is holding) and the two 10mm bolts are undone, you should be able to lift the cover up high enough to slide the air filter out and slide the new one in. Pay close attention to the orientation of the filter. Look for indents, patterns and labels or arrows that say front or flow. Once the new one is in, lower the cover, resecure the bracket and the 10mm bolts. you are done. steviej Quote Link to comment Share on other sites More sharing options...
steviej Posted November 7, 2006 Share Posted November 7, 2006 Is this the same for the 2005 ES-330? Thanks. I would assume so, but I haven't looked under the hood of an 05/06. steviej Quote Link to comment Share on other sites More sharing options...
mburnickas Posted November 7, 2006 Share Posted November 7, 2006 Is this the same for the 2005 ES-330? Thanks. I would assume so, but I haven't looked under the hood of an 05/06. steviej WOW..bringing out the old-school threads! Quote Link to comment Share on other sites More sharing options...
carlexes330 Posted March 3, 2008 Share Posted March 3, 2008 hello,Any instructions / links about replacing air filter are very welcome Replace it with a K& N filter from Pep Boys or autozone excellent with 1 million mile warranty and cost around $50 clean and reoil every 50K superb upgrade Quote Link to comment Share on other sites More sharing options...
es330iwanna Posted September 2, 2008 Share Posted September 2, 2008 hello,Any instructions / links about replacing air filter are very welcome Replace it with a K& N filter from Pep Boys or autozone excellent with 1 million mile warranty and cost around $50 clean and reoil every 50K superb upgrade carlexus330, I bought a K&N but am not able to slip it in.. I can't get the lid to go back into the plastic hinge.... Did you have any issue? What model number did you buy? Mine is a 33-2260. I did not unscrew the phillips head screw as mentioned in the instructions though. Any comments on how you got it to fit would be greatly appreciated. Thanks. Quote Link to comment Share on other sites More sharing options...
gstowe Posted October 4, 2008 Share Posted October 4, 2008 I have a 1996 ES300 and am trying to replace the air filter. I see the 4 clips but still can't lift the cover high enough to remove/install the filter. Any suggestions? Quote Link to comment Share on other sites More sharing options...
blk_on_blk Posted October 5, 2008 Share Posted October 5, 2008 Our '95 ES300 has the four clips, and it's just stiff to lift up... the air duct is just stiff material. If it's like mine (and it should be), just flex it up a little more and you can get the filter out... just double check to ensure there aren't any vacuum lines getting tugged on when you lift up. Quote Link to comment Share on other sites More sharing options...
carlexes330 Posted January 21, 2009 Share Posted January 21, 2009 Our '95 ES300 has the four clips, and it's just stiff to lift up... the air duct is just stiff material. If it's like mine (and it should be), just flex it up a little more and you can get the filter out... just double check to ensure there aren't any vacuum lines getting tugged on when you lift up. Replace the standard air fiter with a K& N part # 33-2260 Product Specifications Product Style: Panel Air Filter Height: 0.938 in (24 mm) Outside Length: 12.563 in (319 mm) Outside Width: 7.563 in (192 mm) Filter Re-Oiling Amount: 1.22 oz (36 ml) Weight: 1 lb (0.4 kg) Product Box Length: 7.72 in (196 mm) Product Box Width: 1.75 in (44 mm) Product Box Height: 13.56 in (345 mm) For around $50 it is a million mile filter that needs cleaning every 50,000 miles and is far superior to the crazy priced Lexus filter Quote Link to comment Share on other sites More sharing options...
