Rx330 Hid
skbb
Same as any other HID. Probably just differant optics in the housing that makes the color change, but if you look at the 330's they also turn purple, white as you look at them from differant angles
In this case is it worth upgrading the oem HID (4300-5000k) to HID 6000K RAYBRIG D2S(color bluish and purplish 6000k)HID bulb 2pcs 1set 28,050yen.Thanks
No - that won't do you any good. Lamps burning at 6000K are a lot harder to see the road than lamps at 4100 - 4800. You eye balls just don't work that way.
Besides - you'll *BLEEP* off every driver that you drive past or drive up on! Possibly get the attention of the police too!
Thanks for the replies, the purplish color is more apparent on german cars than that of lexus.You can actually tell from a long distance that the car behind is either bmw or mercedes.The change in color is awesome. :)
