How To Remove Center Console
lewjeff
05 RX 330
I have something sliding around under my center console.
If I slide/hold the console all the way back, whatever it
is in there, is jammed tight and the noise stops.
How the heck do you remove the entire center console?
I'd let Lexus find the problem.
:rolleyes:
05 RX 330
:rolleyes:
I agree. Don't even think twice about it. Let them figure it out.
05 RX 330
I bought it in Feb w/5000 miles on it (demo) and it
always had the problem, so I know I didn't do it.
In hindsight, I should have had them look at it
at the first maintenance schedule.
My concern is it is a coin or something like that,
and they'll blame it on me. I was thinking if it was
easy to remove the center console, I do it myself.
Even if it is a coin or something like that, would it
still be covered under warranty?
On each side of the console there is a cover remove under each cover there is 3 10mm bolts remove them. The front of the console comes off under there is a plug for the light in the center console unplug. Now on the passenger side there is the cable that is attached to the handle that lets you slide the console back and forth once you remove all those things the console will lift rite out.
05 RX 330
Are you talking about the console were the stero is ?
If so heres a step by step removal guide
http://www.carstereohelp.com/stereoremovalLexusRX330Str.htm
Does not matter what the heck it is!! Its under warrenty period!
Since you know exactly where it is they should be able to do it while you wait--probably a 10 minute job, I know my service guy wouldnt even think twice about doing it right there--I mean he would do it with no problem
