Zephyr Posted July 21, 2003 Posted July 21, 2003 Hi i'm sorry if this was posted before, but i have moisture in my headlamps. HOw do i take out the headlight assembly? I know there are two visible screws. Is that it? Can anyone provide instructions? I also need to open out the housing, do i need to put it in the oven? Please help. Thank you
bartkat Posted July 21, 2003 Posted July 21, 2003 Here's a pic DIY for removing headlights. http://my.is/forums/showthread.php?t=226292
Inocente Posted October 23, 2006 Posted October 23, 2006 Here's a pic DIY for removing headlights. http://photos.yahoo.com/bc/monetaryfund/ls...=ph&.view=t that link you put up doesn't work, is there any way you can send those pictures to me?
bartkat Posted October 23, 2006 Posted October 23, 2006 Sorry, that link was bad. This one should work. http://my.is/forums/showthread.php?t=226292
Rx330driver Posted October 24, 2006 Posted October 24, 2006 that seems like a lot of work, if you still have the car under warranty they will change the entire headlight unit for free like they did with my car.
Inocente Posted October 26, 2006 Posted October 26, 2006 Sorry, that link was bad. This one should work. http://my.is/forums/showthread.php?t=226292 thanks bartkat
nme187 Posted April 9, 2011 Posted April 9, 2011 Sorry to bump an old thread but google lead me here and decided to give my 2 cents. So I changed both low-beams today w/o removing the bumper/headlight housings; even with gorilla hands it's possible and doable under 30 min. The right side is cake and if you need more room then unmount that relay bracket sitting behind the housing. The left side is more of a pain but still easy. disconnect the diag port on the fuse box to make more room and disconnect both harness that connect to the back of the headlights; I believe one connector is for the HID's, and other is the parking light?
