Lexuses71 Posted November 15, 2005 Posted November 15, 2005 Today, for the 1st time, when I turned my headlights on this early AM, my dash lights did NOT dim a bit. Is this normal or do I have some crossed wires? Up until now, whenever I turn the switch on for headlights, the dash dims a bit. Even my ES300 does the same thing. I figured that's just the normal "electrical drain" on the battery. When I tun them off at my destination, the dash lights get noticably brighter. So, why all of a sudden would they NOT dim? I even had the fogs on. Anybody else experience this? And is it a sign something is not quite right?
Celsior Dude Posted November 15, 2005 Posted November 15, 2005 Today, for the 1st time, when I turned my headlights on this early AM, my dash lights did NOT dim a bit.Is this normal or do I have some crossed wires? Up until now, whenever I turn the switch on for headlights, the dash dims a bit. Even my ES300 does the same thing. I figured that's just the normal "electrical drain" on the battery. When I tun them off at my destination, the dash lights get noticably brighter. So, why all of a sudden would they NOT dim? I even had the fogs on. Anybody else experience this? And is it a sign something is not quite right? ← Ddi you have the brightness on max, when in this position normally the dash lights don't dim when the headlights are on.
Lexuses71 Posted November 15, 2005 Author Posted November 15, 2005 Did you have the brightness on max, when in this position normally the dash lights don't dim when the headlights are on. ← Ya know, I'd have to look at that. I did go to the car wash Saturday and you know how they wipe stuff down, messing with your volume control, etc. So, the guy could have moved the brightness setting to max by accident and I just didn't notice. Will check tomorow AM if it is on max setting, thanks, excellent point. Baby's chilling in the garage right now, so manana I'll sure find out.
GRAND_LS 4 Posted November 15, 2005 Posted November 15, 2005 Did you have the brightness on max, when in this position normally the dash lights don't dim when the headlights are on. ← Ya know, I'd have to look at that. I did go to the car wash Saturday and you know how they wipe stuff down, messing with your volume control, etc. So, the guy could have moved the brightness setting to max by accident and I just didn't notice. Will check tomorow AM if it is on max setting, thanks, excellent point. Baby's chilling in the garage right now, so manana I'll sure find out. ← Thats what it is.
Lexuses71 Posted November 17, 2005 Author Posted November 17, 2005 Did you have the brightness on max, when in this position normally the dash lights don't dim when the headlights are on. ← Ya know, I'd have to look at that. I did go to the car wash Saturday and you know how they wipe stuff down, messing with your volume control, etc. So, the guy could have moved the brightness setting to max by accident and I just didn't notice. Will check tomorow AM if it is on max setting, thanks, excellent point. Baby's chilling in the garage right now, so manana I'll sure find out. ← Thats what it is. ← YEP! That was EXACTLY what happened, thanks fellas! All's well now.
shm1 Posted September 20, 2006 Posted September 20, 2006 how would i change a light bulb for the dashboard clock? thanks
LRP_LS400 Posted September 20, 2006 Posted September 20, 2006 is this what you're talking about w/ new leds, you will have to take apart the center dash part and switch out the lights
