Black Lex Posted October 28, 2005 Posted October 28, 2005 I bought the car with 125,000 on it . called dealers that had mantinance on car one uses ps. fluid and the other uses tranny(dexron) Like in manual I would like to top up but I hear that tranny fluid installed from manufacture is a clear color . I have no Idea what I have in. can I mix or do I have to flush and fill with dexron I now have 150,000 on
SKperformance Posted October 28, 2005 Posted October 28, 2005 What do you mean by one uses PS and the other uses tranny The one and the other what???? It should be the same red fluid from yoru tranny as your ps pump.
nc211 Posted October 28, 2005 Posted October 28, 2005 dude, slow down on the typing..... you're all over the place. first off, your tranny fluid shoud be ANYTHING but clear! Normal oem fluid is red. Worn out fluid should be dark brown. Clear is not an option for tranny fluid.
SRK Posted October 28, 2005 Posted October 28, 2005 I think I understand you BlackLex. Someone has told you that the power steering system uses clear PS fluid, and someone has told you it takes ATF - Dexron. The correct fluid for the power steering is Dexron ATF (which stands for automatic transmission fluid of course) The clear power steering fluid is similiar in most respects, but the factory calls for ATF, and all ATF's that I am aware of are red, and that's what you should use.
Black Lex Posted November 2, 2005 Author Posted November 2, 2005 I think I understand you BlackLex. Someone has told you that the power steering system uses clear PS fluid, and someone has told you it takes ATF - Dexron. The correct fluid for the power steering is Dexron ATF (which stands for automatic transmission fluid of course) The clear power steering fluid is similiar in most respects, but the factory calls for ATF, and all ATF's that I am aware of are red, and that's what you should use. ← I have heard that the Dexron ATF that comes in powersteering from the factory is clear in color. I checked and it is clear in color (like ps fluid) .I suspected that one of the lexus dealers that mantained my car before I bought it replaced fluid with ps fluid seeing that one had rebuilt ( changed the rubber rings) on my pump. So I called and they told me that they indeed do use power steering fluid when replacing fluid ! So I thought I would check other dealers . I called six different Lexus dealers and half said use PS and the other half said dexron atf (as in manual) I could hardly believe my ears. The fluid in pump is a little low and I don't know what to top it off with. I don't think mixing the two fluids in a very good idea. I guess I will have to flush and replace with dexron atf to make sure.
monarch Posted November 2, 2005 Posted November 2, 2005 It says right on the cap of your PS pump reservoir cap to use "Dexron ATF". So any Dexron II or III automatic transmission fluid will be OK. Yes the factory fill fluid in the PS pump reservoir is clear to light tan in color. Many owners mistakenl think the tan color means the fluid is dirty, but it's not. Even the factory fill fluid in a 2006 Lexus is light tan.
GRAND_LS 4 Posted November 2, 2005 Posted November 2, 2005 It says right on the cap of your PS pump reservoir cap to use "Dexron ATF". So any Dexron II or III automatic transmission fluid will be OK. Yes the factory fill fluid in the PS pump reservoir is clear to light tan in color. Many owners mistakenl think the tan color means the fluid is dirty, but it's not. Even the factory fill fluid in a 2006 Lexus is light tan. ← true, I replaced mine with Mobil 1 ATF, best move I ever made :D Steering is much better now.
sha4000 Posted November 2, 2005 Posted November 2, 2005 It says right on the cap of your PS pump reservoir cap to use "Dexron ATF". So any Dexron II or III automatic transmission fluid will be OK. Yes the factory fill fluid in the PS pump reservoir is clear to light tan in color. Many owners mistakenl think the tan color means the fluid is dirty, but it's not. Even the factory fill fluid in a 2006 Lexus is light tan. ← true, I replaced mine with Mobil 1 ATF, best move I ever made :D Steering is much better now. ← did the same thing and what a difference
Black Lex Posted November 13, 2005 Author Posted November 13, 2005 What do you mean by one uses PS and the other uses trannyThe one and the other what???? It should be the same red fluid from yoru tranny as your ps pump. ← Sorry that I had a confusing post there I meant to say PS fluid /Dexron in the powersteering .
Black Lex Posted November 13, 2005 Author Posted November 13, 2005 dude, slow down on the typing..... you're all over the place. first off, your tranny fluid shoud be ANYTHING but clear! Normal oem fluid is red. Worn out fluid should be dark brown. Clear is not an option for tranny fluid. ← I'm Sorry again my original post was confusing. I was addressing the P.S. - (power steering fluid)VS ATF Dexron (Auotomatic Transmission Fluid) For the powersteering resevoir. I Was in a hurry that night ...... thanks every body for bearing with me.
Black Lex Posted November 13, 2005 Author Posted November 13, 2005 It says right on the cap of your PS pump reservoir cap to use "Dexron ATF". So any Dexron II or III automatic transmission fluid will be OK. Yes the factory fill fluid in the PS pump reservoir is clear to light tan in color. Many owners mistakenl think the tan color means the fluid is dirty, but it's not. Even the factory fill fluid in a 2006 Lexus is light tan. ← I thank you and others that have replied to my post . But I would still like a answer to my original question .... Can I mix the two ???? or should I flush??
dfkd Posted November 13, 2005 Posted November 13, 2005 Since you're not sure what's in there right now i would suggest you flush and do what the freaking manual says to do do. I dont see why they (the mechanics) didnt do that from the beginning
GRAND_LS 4 Posted November 13, 2005 Posted November 13, 2005 It says right on the cap of your PS pump reservoir cap to use "Dexron ATF". So any Dexron II or III automatic transmission fluid will be OK. Yes the factory fill fluid in the PS pump reservoir is clear to light tan in color. Many owners mistakenl think the tan color means the fluid is dirty, but it's not. Even the factory fill fluid in a 2006 Lexus is light tan. ← I thank you and others that have replied to my post . But I would still like a answer to my original question .... Can I mix the two ???? or should I flush?? ← Yes, you can mix the two. You can keep draining and refilling till its completely red.
