norbertk Posted October 4, 2005 Share Posted October 4, 2005 I decided to go into the radio and HVAC console as my volume knob slipped off it's alignment. I was planning on fixing the lighting problem I'm having. Here is my console: Console HVAC The area in the Red is what was lighting up before I started taking it apart. Green is what started working after I put it all together. What could have caused the switch? The three lights that are under the LCD screen can't be taken out, and I would have to bend the LCD screen all the way out to try and replace them. Is it just the connection? RADIO As you can see, it's pitch black. I took a picture of the PCB: PCB This is without the treble/bass knobs. Anyone know how to replace these small bulbs or what the part number is? -Question> What happens if I remove the blue condom from the lights? Quote Link to comment Share on other sites More sharing options...
SKperformance Posted October 4, 2005 Share Posted October 4, 2005 You can take the bulbs out as i have changed mine as well. You need to remove the screen by pulling the face plate off. It was over 6 years since i did mine so i am not very fresh on details. Quote Link to comment Share on other sites More sharing options...
norbertk Posted October 4, 2005 Author Share Posted October 4, 2005 I'm not talking about the button lighting bulbs. Though I changed without a problem. I'm talking about the 3 lights that are inside and behind the LCD which are soldered in. Quote Link to comment Share on other sites More sharing options...
