I decided to go into the radio and HVAC console as my volume knob slipped off it's alignment. I was planning on fixing the lighting problem I'm having. Here is my console:
Console
HVAC
The area in the Red is what was lighting up before I started taking it apart. Green is what started working after I put it all together. What could have caused the switch? The three lights that are under the LCD screen can't be taken out, and I would have to bend the LCD screen all the way out to try and replace them. Is it just the connection?
RADIO
As you can see, it's pitch black. I took a picture of the PCB:
PCB
This is without the treble/bass knobs.
Anyone know how to replace these small bulbs or what the part number is?
-Question> What happens if I remove the blue condom from the lights?
You can take the bulbs out as i have changed mine as well.
You need to remove the screen by pulling the face plate off.
It was over 6 years since i did mine so i am not very fresh on details.
I'm not talking about the button lighting bulbs. Though I changed without a problem. I'm talking about the 3 lights that are inside and behind the LCD which are soldered in.
