My 95 ES300 is making rattling noises in the rear of my car when I go over any bumps. They seem to be getting louder. I think it might be my struts. Any ideas???
most likely yea :( it could be the wheel bearings, but there would be noise even on smooth pavement. i experienced rattling noise at the front end of my car when going over small bumps but not on smooth pavement. the mechanic told me the struts were a little bad and i could still drive the car but since its a luxury car, the noise can get really annoying :angry: i suggest having your car check out by a mechanic and if it is your struts, there are some being sold in ebay on a daily basis.
also may sound stuipid but check your center caps on your rims and make sure there tight.i had a noise once in the front of my car when i hit a bump and it was that.if not then its most likely the struts.
you say rattling usually the bushings in the rear suspension goes and causes a squeeking
if it is a rattle than it would need to be checked by a shop
it could be a bolt loose in the trunk
