lexus411 Posted September 30, 2005 Posted September 30, 2005 Lexus will make satellite radio available in Feb 06 for the 06 RX's. Once that happens there will be a kit retroactive for the 06's sold prior.
ctrx Posted October 4, 2005 Posted October 4, 2005 Lexus will make satellite radio available in Feb 06 for the 06 RX's. Once that happens there will be a kit retroactive for the 06's sold prior. ← Will the kit work for the '05 RXs?
lexus411 Posted October 4, 2005 Author Posted October 4, 2005 So far I dont think it will for some reason. It wont work on the 400h either. Hopefully they will have something for both soon.
Station Man Posted October 5, 2005 Posted October 5, 2005 I just bought an 06 and it had a Sirius sat radio in it. The salesguy said they installed it after they got the car. He told me the same thing about them coming from the factory in Feb of 06.
lexus411 Posted October 5, 2005 Author Posted October 5, 2005 These are actual factory untis that are pre-installed so it works through the original radio. Only currently available on the ES,GS,LS and LX.
papan Posted October 5, 2005 Posted October 5, 2005 These are actual factory untis that are pre-installed so it works through the original radio. Only currently available on the ES,GS,LS and LX. ← Well can I get it in my 2005 RX
lexus411 Posted October 5, 2005 Author Posted October 5, 2005 We probably won't have full details until the new year. This is planned for Feb production. So they probably start shipping the conversion kit as well. I ll post more info when I get it
Rodie Posted October 6, 2005 Posted October 6, 2005 So far I dont think it will for some reason. It wont work on the 400h either. Hopefully they will have something for both soon. ←
Rodie Posted October 6, 2005 Posted October 6, 2005 Is the system installed through the standard radio ? My dealer seems not to want to install. Looking at a 06. They never said anything about it being avail. in the 330.
lexus411 Posted October 7, 2005 Author Posted October 7, 2005 will be a mid year change. We may even see the 350 engine in the RX at that time as well. Both should be in the cars in March at the dealerships.
Gray Wolf Posted October 21, 2005 Posted October 21, 2005 Lexus will make satellite radio available in Feb 06 for the 06 RX's. Once that happens there will be a kit retroactive for the 06's sold prior. ← Thanks for the info. What is the source for the kit info? Any info on if the kit will work with the current 06 in-dash unit or will it require a new radio as well? Does anyone know if there is an aftermarket satellite in-dash unit currently available? If so does it work with the steering wheel controls? I've seen the posts about the AC controls etc. making it difficult but was wondering if maybe the demand has created a market for one.
zube Posted December 8, 2005 Posted December 8, 2005 You can get it know i did two RX 330 today one with sirius one with XM. I used a ES 330 kits for both of them you just have to get creative with mounting them some were.
Booyah Posted December 9, 2005 Posted December 9, 2005 You can get it know i did two RX 330 today one with sirius one with XM. I used a ES 330 kits for both of them you just have to get creative with mounting them some were. ← Using what radio? how much is this procedure and are you a mechanic.
zube Posted December 9, 2005 Posted December 9, 2005 I work for car electronic store and we do all the aftermarket installs for a big Lexus dealership.Like I said I used the factory XM and Sirius kits from a 2006 ES 330. But since there is no kit made for this car you have to get creative. I put both units behind the glove box in the passenger kick panel there is room in th RX 330. The rx 400 has a couple extra modules in ther so you have to go all the way to the back of the truck under the rear storage compartment. If you want to do sirius in a RX 400 I suggest you use a LX 470 kit cause the harness is longer. If you have ever seen any of the kits there is a part of the harness that want you to go to the factory amp. The only thing they get from the factory amps constant power(yellow wire) and ground(black). So you can cut that out and get constant and groung anywere you want. I've also done a Gx 470 that also work fine. The only thing I found that was funny on the RX instead of spelling out SAT on the screen it says TAT1 TAT2 TAT3 but other than that everthing works great.
Booyah Posted December 9, 2005 Posted December 9, 2005 SO using the factory radio in an say 04RX all I need is the XM kit? DO you want to come visit Alaska for a week or two and hook me up:)
zube Posted December 9, 2005 Posted December 9, 2005 I dont see why it wouldnt work on a 04 RX . And im sorry I really dont like cold weather.
