My 1999 LS400 is at 91K and I just have the timing belt and water pump replaced. I am now thinking about replacing the spark plugs and wires, any suggestion on the brand? I heard about Iridium spark plugs and Vitek wires. Has anyone has any experience with those? Should I just stick to OEM?
Paul
I just put iridums in my 98 and i like them ,not a major change but i will have to finish a tank of gas to know any milage increases.
I don;t have wires but will suggest you only use OEM and not HGK ones as they are garbage.
Stick with OE plugs......in your case, that might mean laser platinums instead of iridiums. They are very good & should last 100,000 miles. B)
:cheers:
i purchased vitek wires and ngk iridium plugs and they work fine the only issue was with the wires, they were of different lengths and didnt fit as snuggly as i'd have liked but overall i cant complain
  :cheers:
the iridium plug is OE for his car
 :cheers:
My bad, I stand corrected.......had a brain cramp & thought for some reason he had an early 90's LS. :blushing: ;)
:cheers:
just changed mine-got oe plugs from lexus -they were PK20R-11 which are platinum.
and after market leads which were cheaper by 100 bucks . fit ok .you must follow exactly the instructions from lexls.com and lextacy.com where u will find the wire routing instructions. or the service manual if u have access to one.if u dont run the wires exactly as shown in the correct wire holders u can crimp them when u put covers back on and then u get missfireing.trust me. i destroyed a set and had to go buy another. luck i bought the cheap ones!
