Spark Plug And Wire
ptd0647
My 1999 LS400 is at 91K and I just have the timing belt and water pump replaced. I am now thinking about replacing the spark plugs and wires, any suggestion on the brand? I heard about Iridium spark plugs and Vitek wires. Has anyone has any experience with those? Should I just stick to OEM?
Paul
Stick with OE plugs......in your case, that might mean laser platinums instead of iridiums.  They are very good & should last 100,000 miles.   B)
 :cheers:
the iridium plug is OE for his car
My bad, I stand corrected.......had a brain cramp & thought for some reason he had an early 90's LS. :blushing: ;)
:cheers:
just changed mine-got oe plugs from lexus -they were PK20R-11 which are platinum.
and after market leads which were cheaper by 100 bucks . fit ok .you must follow exactly the instructions from lexls.com and lextacy.com where u will find the wire routing instructions. or the service manual if u have access to one.if u dont run the wires exactly as shown in the correct wire holders u can crimp them when u put covers back on and then u get missfireing.trust me. i destroyed a set and had to go buy another. luck i bought the cheap ones!
