bicol-ini Posted September 19, 2005 Posted September 19, 2005 hello, ive got a 96 repair manual, but am doing a 98 LS400 repair for a friend, looking for a pdf for the front and rear shock replacement and the steering rack repalcement pdf, am not sure if there is a difference, just trying to compare, before i started the work, thanks for any info /help
dcfish Posted September 19, 2005 Posted September 19, 2005 hello, ive got a 96 repair manual, but am doing a 98 LS400 repair for a friend, looking for a pdf for the front and rear shock replacement and the steering rack repalcement pdf, am not sure if there is a difference, just trying to compare, before i started the work, thanks for any info /help ← Hope this helps ;) LS400_SHOCKS.pdf LS400_SHOCKS_REAR.pdf power_steering.pdf power_steering_specs.pdf
bicol-ini Posted September 20, 2005 Author Posted September 20, 2005 dcfish thanks a lot for the reply, its pretty much the same as for my 96 i compare it with my repair manual,
lexus400 Posted September 21, 2005 Posted September 21, 2005 I've done the rears w/o removing the parcel shelf, caliper and driveshaft on a couple of gen I cars. The instructions look the same for both. I don't know why the have you do so much disassembly... Bob
bicol-ini Posted September 21, 2005 Author Posted September 21, 2005 i agree with you when i did my 96 for the rear i didnt remove the drive shaft and the package shelf, its probably the same for the 98, am gonna do this over the weekend, i think dealers wants something like 1000 bucks give or take for front and rear struts replcement not counting on what they found out more, like the bumpers and rubber protection on the aoutside
bicol-ini Posted September 25, 2005 Author Posted September 25, 2005 hi did it today replaced my friends 98 LS front and rear struts plus bumper and insulator parts for front and rear 500 bucks total cost, stealer wants 1000 bucks
blake918 Posted March 21, 2006 Posted March 21, 2006 hi did it today replaced my friends 98 LS front and rear struts plus bumper and insulator parts for front and rear 500 bucks total cost, stealer wants 1000 bucks The last time I was putting my spare on I notcied the insulator looked really beat up. I'm going to change my struts soon, are the insulators worth replacing "while I'm in there?"
Threadcutter Posted March 21, 2006 Posted March 21, 2006 blake: are the insulators worth replacing "while I'm in there?" Yes..................They're cheap & easy to replace. The springs are the biggest hassle. (To eliminate joint ache, take three aspirin BEFORE commencing work.........Yes, I'm being serious.)
